set X-over freq or leave it alone?
Hi all!
here is our PA setup:
Mackie onyx 1640 mixer
Driverack PA
2 - JBL SF25 main cabinets (2x 15s and a horn w/built in x-over)
1 - JBL MP418SP powered sub (2 internal Crown 660w power amps w/x-over @ 120Hz)
1 - JBL MP418S
1 - QSC PLX-3402 power amp (for the SF25's)
I used the wizzard to setup the system, I'm going to run the PLX 3402 in stereo to the SF25 cabinets.
my question is, should I set the crossover freq in the driverack for the MP418 sub or just leave it alone?
Thanks!
Driverack PA
1 - JBL MP418S
Thanks!
I would select a 2 x3 with 100 hz LPF for the subs at LR 24, with an HPF of 50 hz and bw 18 slope...Likewise a 100 hz LR 24 HPF for the SF25's use about 8.5 ms of delay for the tops...there is no LPF so 'out' would be the correct term here...
So yes, I would cross the subs and the tops at the same point.. in the future it would be appreciated if you would include ALL the info you have and all of what you want to know...
here is the only info I could find on the SF25:
Features & Specs
SF25
3/4\" MDF advanced cab construction
2 - 15\" woofers with 2-1/2\" voice coils
Ferrofluid-cooled titanium driver
500W program handling
2,000W peak handling
Advanced crossover topology
4-ohm nominal impedance
18.25\"W x 43\"H x 17\"D
94 lbs.
and here is what I found on the MPro MP418SP:
Speaker System Type: Powered 18\" subwoofer, bass-reflex enclosure
Frequency Range (-10 dB): 36 Hz - 150 Hz
Frequency Response (±3 dB): 40 Hz - 120 Hz
Sensitivity (1w/1m)1: 101 dB SPL
Nominal Impedance: 4 ohms
Rated Maximum SPL2: 132 dB SPL peak
Dimensions (H x W x D)3: 617.9 mm x 538.1 mm x 776.6 mm
(24.33 in x 21.19 in x 30.57 in)
Net Weight: 54 kg (119 lbs.)
Drivers: 1 x JBL 2241G
Optional Accessories: SS3BK pole
Amplifier
Amplifier Power4: 660 watts @ 4 ohms (per channel)
400 watts @ 8 ohms (per channel)
Crossover Frequeency: 120 Hz
Required AC Mains: 50/60 Hz (North American units are 60 Hz only);
120 and 230-240 VAC (±10%) units are available
AC Line Current: 120 volts: 9.5 A; 230 Volts ±10%: 5.0 A
Power Consumption at Idle: No more than 90 watts
Total Harmonic Distortion: 1 kHz rated power, 0.5% or less true THD from
20 Hz to 20 kHz
and the QSC PLX3402:
PLX3402
STEREO MODE, Both Channels Driven
8 ohms (20 Hz-20 kHz 0.03% THD) 700 W
4 ohms (20 Hz-20 kHz 0.05% THD) 1100 W
2 ohms (1 kHz 1% THD) 1700 W
BRIDGE MONO MODE
16 ohms (20 Hz-20 kHz 0.1% THD) 1400 W
8 ohms (20 Hz-20 kHz 0.1% THD) 2200 W
4 ohms (1 kHz 1% THD) 3400 W
Signal to Noise (20 Hz-20 kHz) < -107 dB
Input Sensitivity @ 8 ohms 1.9 Vrms
Input Sensitivity @ 4 ohms 1.7 Vrms
Voltage Gain 40x (32 dB)
Output Circuitry 2-Step Class H
Power Requirements
(1/8 Power Pink Noise @ 4 Ohm) 12A
Distortion (SMPTE-IM) Less than 0.01%
Distortion (Typical)
20 Hz-20 kHz: 10 dB below rated power
1.0 kHz and below: full rated power
Less than 0.01% THD
Less than 0.01% THD
Frequency Response 20 Hz-20 kHz, +/- 0.2 dB / 8 Hz-50 kHz, +0, -3 dB
Damping Factor Greater than 500
Input Impedance 6k ohms unbalanced, 12 k ohms balanced
Input Clipping 10 Vrms (+22 dB)
Cooling Variable-speed fan, rear-to-front air flow
Connectors, each channel Input: 3-pin XLR & 1/4\" TRS balanced
Output: Neutrik® Speakon® and touch-proof binding posts
Amplifier Protection Full short circuit, open circuit, thermal, ultrasonic, and RF protection
Stable into reactive or mismatched loads
Load Protection On/off muting, DC-fault power supply shutdown
Dimensions 19\" (48.3 cm) rack mounting, 3.5\" (8.9 cm) tall (2 rack spaces)
13.25\" (33.7 cm) deep (from front mounting rails)
Gain 40x (32 dB)
Weight 21 lbs (9.5 kg) net, 27 lbs (12.3 kg) shipping
and yes, I am using the MP418SP in sub+sub mode with the MP418S (unpowered), so that's 660w to the unpowered sub.
what would work better for power on the subs?
also, the wizard setup the system as 2x4, and since my speakers are listed in the wizard, is the crossover already set for the SF25's and the MP418SP?
the reason I'm asking is because I did some more reading on this forum and the \"old\" forum and I was lead to believe that if your speakers are listed in the wizard, the crossover is set by the wizard, is that correct?
Thanks again!
Dra
