new set up need help
My set up is
mackie mixer
driverack pa
1 crown xs1200 driving
2 top speakers fd-15h1 from tr
2 crown ce2000 bridge driving
2 subs th-118b from tr
AMPS FOR TOPS CROWN XS1200
IN 8 OHMS 650+650 2 CHANNEL
AMPS FOR THE SUBS 2 CROWN CE2000
BRIDGE AT 8 OHMS FOR 1320W EACH
SO EACH AMP IS DRIVING IS OWN SUB
FD-15H1 X2
Frequency range:55 Hz - 18 kHz
Sensitivity (SPL 1W @ 1m):99 dB
Maximum SPL:130
RMS (W):400
Peak power (W):800
Impedence (Ohms):8
Passive crossover:2.2 KHz
Dispersion (H/V):60° x 40° (1\")
High frequencies:1� driver
Low frequencies:1 x 15\" woofer
http://www.tr.ca/2006/english/products/ ... d-15h1.htm
TH-118B X2
Frequency range:35 Hz - 500 kHz
Sensitivity (SPL 1W @ 1m):101 dB
Maximum SPL :136.8
RMS (W):750
Peak power (W):1500
Impedence (Ohms):8
Passive crossover:100 Hz
Dispersion (H/V) -
High frequencies -
Low frequencies 1 x 18\"
http://www.tr.ca/2006/english/products/ ... h-118b.htm
my question is on the wizard what do i select as for amps
and if i could use 2 amps bridge for my subs on a 2x4 system.
on the cross over how much gain do i set it to .i ave a idea what will be my settings for my cross over but the gain im not sure.
and how do i set up my comp/limiter for my amps
thank you for your help,its my firts driverack
i love it but its still confusing
mackie mixer
driverack pa
FD-15H1 X2
Maximum SPL:130
RMS (W):400
Peak power (W):800
Impedence (Ohms):8
TH-118B X2
Maximum SPL :136.8
RMS (W):750
Peak power (W):1500
Impedence (Ohms):8
Dispersion (H/V) -
High frequencies -
Keep us informed, or if you can't bypass the internal crossover in the subs let me know...
do i set the gain of the cross over at 0 all
and do a gain structure
As for the gain, start at -0-db in the driverack's gains and adjust them as needed. there is much here about gain structure if you use a keyword search. I really need as much info as you can get me since the site is so bad for those speakers... was the manual any more help?
gadget
