Pinking outside & crossover?
I was told to use the RTA Mic and auto eq outside before I try in a venue. My question is after I auto eq outside how do I fix the issues with my speakers by using the PEQ? My second question is when talking about crossover settings like 50hz
BW 24, what does the BW24 stand for?
Eric
Eric
The goal is to get your system as flat as possible so that every venue you go into you have a place to start and you only have to deal with the room. The end result of the flattening session should be saved and never adjusted (in theory).
Dra
