Set up for EV+QSC
We justed ordered a new Driverack PA. It's on the way and I could use a little help getting started with the setup. I'd appreciate any help at all. We're using the following:
2xElectrovoice G115 (Hi/mid)
4xElectrovoice G118 (sub) (connect 2L and 2R)
1xQSC PLX 3002 (hi/mid)
1xQSC PLX 3002 (low)
p.s. live sound an DJ
Your speakers want more power than you can give them, especially the subs. Consider running the subs together off the 3002 bridged.
Set up a 2 x 3 (stero in, stero out with mono sub) EQ should be stereo linked.
Cross over:
Sub - Hi-pass 45hz (or higher because of power) BW18
Lo-pass 100hz LR24
Tops - Hi-pass 100hz LR24
Set gain structure per back of manual (also read on board)
Set limiter (as part of gain set up)
Compressor - Use only if absolutely neccessary
Sub-synth - \"\" \"\" \"\"
PEQ's - Read up
Auto EQ - Will ruin sound if you assume that it does what you think (read up)
AFS - read up
Download the 260 driveware and play with it. It will help you see what the DRPA is doing (on common features).
Dra
