Weekend Gig Help
Hey DBX Forum Gods,
I have a gig this weekend and was wondering if I could get some help on configuring my setup/crossover config etc. so I don't look like to much of an Am. Listed below is the setup I will be using.
2) B52 MX-1515 600 Watts each 4ohm Mains (2 15\" and a Horn in each Cab)
2) ARM 12\" Monitors 250 Watts each 8ohm
2) QSC RMX 1850 HD Power Amps
1) Crest Performance Audio CPX 2600 Power Amp
1) Mackie 1604 VLZ Pro Mixer
1) DBX Drive Rack PA
1) Alesis 3630 Compressor
1) Alesis Nano Compressor
1) Alesis Nano Verb
1) Alesis MicroVerb
1) Furman Q 2312 (2) 31 band EQ
1) Sony RCD-W500C Disc Recorder
I know this is all am. gear but I'm trying to learn to see if it's worth investing my life savings into. Thank You for your help!
1) Alesis Nano Verb
1) Alesis MicroVerb
to do both youd need at least another PA unit as a minimum....
