DRIVERACK PA INPUT
Hi all,
I've just bought an Ecler NUO4 mixer and had a question about the inputs on the driverack PA. The NUO4 has an option of either 0db or 6db output with the use of internal jumpers. I know most pro audio equipment is 4db (correct me if I'm wrong), so could someone please let me know if the 6db setting that I have the mixer on will be ok to use with the driverack?
Thanks again.
Thanks again.
Should work ok.. try it out and see.. most line level sources can plug and play without fear of damage. The only rub might be noisy signals if the signal isn't strong enough, and clipping if it's hit too hard...
