Custom settings
SonicPadawan
Is it possible to rename the \"Custom\" label to something more device specific? For example, I have EV mains that aren't on a list. If I start with \"Custom\" and adjust my settings, is there a way I can put those settings with the rest of the presets and label it accordingly?
To which DriveRack are you refering to?... In the DR260 with the DriveWare GUI in the config mode you can left click on the outputs (For example: \"Left High\") and label them anything you like up to 11 characters...
Kevin
Is this DRPA lingo?... I know in the DR260 you can name your programs what ever you like... I have three custom programs in the one I installed: \"Youth Live\" \"Youth Cinema\" and \"Youth DJ\"...:)
Hey pilgram,...I'm the only \"pandawan\" or \"grasshopper\" around these parts...:D
Kevin
That is the one of the beauties of the 260. You can name the output channels to be the amps or speakers that should connect to that output.
Hey Sonicpadawan,
What you want to do is go with the \"Custom\" program... Once you have setup your program then click on config and then click on the output name like \"Left High\" and name it anything you like... Also you can name your program anything you like,...but you have to keep it clean...:)
Cheers,
Kevin
PS. Dra,...I just saw your write-up in \"Audiophile\"... I got to get ready to go do the \"Friday Night Flick\"... This week it's \"The End of Spear\"... I catch you later this evening...
I'm getting the feeling that neither is possible for me. Call it a quirk, but somehow I'm just not satisfied with leaving it as "Custom". But at the end of the day, whatever, as long as it all works!
Here's the scoop...it's like Dra mentioned...the custom thing disappears once you are finished creating your program, tweaked-it, and your up and running... Trust me on this...don't get hung-up over the custom thing... You still got a lot of work ahead of you... Setup up your crossovers and then move on to gain structure... If you would like some interesting reading click here... This thread has some great informaion scattered all through it... If you need any additional help please ask...
Cheers,
Kevin
Thanks for the help and the link, it's a great reference!
