driverack 260
baez110984
I have a problem with the 260, the screen is going crazy every time I am trying to touch a button and I am using in Stereo and for some reason with either input a or b is working the left and the right side
do any body know why is doing that?
Give us some history of this unit... Is it brand new out of the box?... How old is the unit?... Has anything changed recently i.e. firmware upgrade, cabling, etc.,?... Are you saying that even though the screen is going crazy the unit is operating OK in stereo mode?... How was the unit operating just before it started this?... Tell us everything you can...the more info you can give us the better...
Kevin
If so...
1) Make sure that you don't have your amp(s) in a \"dual mono\" config.
2) Make sure that you are running a stereo x-over or filter.
3) Make sure that the Driverack input mixers are A: fader 1 up, fader 2 down; B: fader 1 down, fader 2 up.
Check these out, but that doesn't help the screen problem.
In regards to your screens...if you bought these units brand new from an authorized dealer then click here and contact DBX Tech Support... If you purchased these units privately from an individual or otherwise...I suggest you open them up and verify that all connections to the screens and keypads are tight... Be advised...once you have opened the units any warranty is void... As far as your stereo inputs are concerned you may not know what your configuration is (stereo or dual mono) unless you can either see the screen or hook-up with the DriveWare GUI… If you haven't already done so...I suggest you download the DriveWare GUI which is provided here and use the cable that came with your DriveRack... Since your an Audio Engineer this should be a \"walk in the park\" for you...
Cheers,
Kevin
