Mannually setting Driverack pa for D-lite dynacord and EV'
My Dynacord D-lite system is composed of two D 12 cabinets passive and one sub 115 passive subwoofer
Dynacord
From the DBX driverack use the DJ setting option:Fullrange or DJ Settings
Press the (wizard) button from the DBX Driverack ----choose (Driverack PA system Setup)
Press(next)
Turn the knob select(Mono) or (Stereo)
Graphic equalization (stereo)
Select (Custom) FOR TOPS
AND (custom) COMPACT SUB) BOTTOMS OR SUB(SELECT STEREO OR MONO)
SELECT (Custom) FOR AMP
FOLLOW THE SAME STEPS AS ABOVE FOR SELECTING LOW LEVEL AMPS****
Select custom amp for tops also select custom for bottom subs
DO a mannual EQ WIZARD.......
Outdoor Auto EQ in a big yard will help
SELECT (XOVER) BUTTON
(L) 45.0 HZ BW 24 GIAN 2.0dB
(L) 200 HZ LR 24
(H) 100 HZ LR 24 GAIN 0.0 dB
SELECT (EQ) BUTTON
SELECT(PEQ &BELL option>)
LEAVE AS IS (FLATTEN OPTION)
SELECT (BELL)
Click on the Image to get the imputs for the EQ set up
select
Low Shelving Filter (LOSLV): f = 200Hz, Slope = 6dB Gain = +3dB, +6dB, +9dB, +12dB
High Shelving Filter (HISLV): f = 2000Hz, Slope = 6dB Gain = +3dB, +6dB, +9dB, +12dB
EQ and press it again and those imput above
use limiters according to what type of amps you' re using.
If anybody has any suggestion please add to it!
Dynacord
Press(next)
(L) 200 HZ LR 24
SELECT (EQ) BUTTON
SELECT (BELL)
2) I am a bit confused as to what the graph is wanting to tell me. (I guess I should say \"why\" is it telling me 4 boosts on Lows and 2 on Highs.)
How does this set-up sound?
