Firmware Update for DRPA
johnk-8
Hello....
Is there a way to update the firmware on a DRPA? I noticed on the updated user manuals.. My speakers and amps are listed in the tuning choices now.
JBL MRX series speakers
CROWN XTI series amps.
John
John
I don't want to ship off the unit.. since I use it constantly.
So... I downloaded the dr260 firmware and entered my speakers and amps to get the x-over setting for my system.
The program gives you a \"amp level setting\" in the PA amplifier dialog box that can be changed. Is this setting where I should set my amps for optimal performance?
My xti2000 setting reads \"56\"
My xti4000 setting reads \"57\"
Or... do I go through a gain structure first... then change the settings in the firmware to match my amp level setting... then go back to the x-over and use the new settings?
I'm confuses on the proper order of steps to get where I want to be.
Another issue I need help with is using compression to ad punch to the system. Does anyone have the optimal settings for compressing the front end?
thank
john
thanks
jk
As an test, do the \"SUPER DUPER\" gain and limiter settings per the procedures and compare with your \"56 / 57\" recommendations, but go with your findings.
As far as using the compressor....
Is there a place for it? Yes
In a band situation? No, unless you want the vocals (and everything else)to drop out every time the kick drum is used.
For a DJ? Maybe, but probably not. If any, used very, very litely.
For a screaming comedian (Sam Kinnessen)? Yes
You said that you wanted punch. Add commpresson to a piece of music and the punch will go away. Sure it will be louder all the time, but it will have no dynamics. Soft should be soft and loud should be loud. Adding compression to music recorded or mixed live, is not the same as compressing a bass guitar or a snare drum. And worse you'll likely over heat your amps because they can't breathe and shorten the life of you speakers, because they can't rest.
