Custom amp setting
I use the Driverack with the DBX 2231 EQ. Our high packs are JBL 415 powered by a Crown XS900 and the low packs are the JBL 418s powered by a Crown Xs 1200. We typically run mono, but have been running in stereo since the purchase of the Driverack. We have the RTA mic and had bad luck with it the 1st time.
I want to ensure i am using the optimal settings for the XS1200 as it is not part of the Wizard.
Also, i see several users do not like the subharmonics. Is it worthwhile to use this if you are using the Wizard.
We want to keep this simple without much 'reprogramming'. The out of the box product seems great, other than the setting up of the 1200.
Any recommendations are welcomed as we are not seasoned veteran at live mixing.
If Dra or Gadget chimes in listen to them and not me...:)
Kevin
Set your limiters (same post) and don't use compression.
Our DRPA does not include the 1200. I believe it only goes as high as the 900.
thanks for the rest of the info.
I just checked and both amps are featured in the DriveWare...:)
Kevin
I guess I was a weeeeieiieeiieiee bit unclear.
I really like your idea of starting off with the DriveWare for the DRPA... It answers lot's of questions right from the start...:D
Kevin
