Bottom End..
We have a new DriveRack Pa.. Before we were splitting up our system by using a the subouts on the board.. We are running two JBL 118s subs and two JBL Jrx125 cabintes.. After going through the DBX and then Pinking the room with the Auto EQ, the bottom end has been reduced dramticaly. It doesnt HIT hard like it used to.
We are having a hard time sweeping the mids and highs on the 125's This DBX has seemed to make us go backwards in our setup... Can anybody give me some suggestions? Do I need to be adjusting the internal crossover on the DBX as well?
I thought thats what the AUTO EQ was supposed to take care of.
Garrett
Garrett
The auto eq is very good but not, unfortunately psychic. It can work out what it can hear but not why it can hear it. For example it can't differentiate between direct and reflected sound. Here's a simple equation which you will probably find elsewhere by searching. It gives you a frequency below which the auto eq can't work but doesn't know it can't work.
Fc=3*(1128/d) where d is the room's smallest dimension in feet. Let it do it's eq and then flatten all frequencies below Fc. EQing below this frequency has to be done either by ear, an analyser like smaart or preferably both. You can't use a reference mic which is what auto eq does.
Bob.
So the effectiveness of auto eq is always going to be ok at high frequencies; it's only the low ones that can't always be eqd.
Bob.
