Crash Course
dangrdangr Posts: 24
edited September 2007 in PA General Discussion
Great forum! Thanx for sharing the knowledge. I put a system together for small and medium rooms for a side project where I'll be playing and providing sound. Bought a separate DBX crossover, dual 31 band EQ, and compressor for lead vocal and gate for kick drum.
Mains JBL JRX125's 500 watts rms at 4 ohms powered by QSC 2450 750 watts to each in stereo.
Subs Peavey PV118's 400 watts program at 8 ohms powered by QSC 1850 380 watts rms to each stereo.
Carvin 1644 mixer
When researhing speakers civilian reviews on internet stores and an educated review on HC about the JBL's touted these speakers as great sounding unbelievable for the price quality, then on the pro forums they're considered junk. I'll have my own opinion this weekend.
OK, so I need to get the best sound I can ASAP, never heard about the Driverack til recently but it looks like a real time saver, eliminate all the trial and error of separate components. Bought DRPA and RTA mic with the impression I'll follow the wizard (my amps and speakers are in updated firmware) auto EQ, AFS etc. I have no place to set up the system except the venue so I can't get to the point where it will tell me if the wizard will:
1) Auto program the crossover points and settings?
2) Autp program the limiters?
and
3)Don't want to use a compressor across everything, guess not a problem to use mine inserted as mentioned above?
4) Guess I should follow manual gain structure procedure and the amp setting suggestions of 37 and 39 are meaningless)?
6) Bought this as a plug and play solution but now reading here that there's a steep learning curve?(I have taught myself basics quickly and of course realize have alot to learn).
The main band I'm in has sound provided, so this will be an adventure. Thanks in advance for answers and input!
  • GadgetGadget Posts: 4,915
    Very briefly...
    Wizard config..set up custom or default to user presets if loaded,
    swap amps use the 2450 bridged on the subs
    set up a 2x3
    set a HP of 45 hz bw18
    set a xover of 99.2 hz(LP) LR 24 for the subs
    set an LR 24 @ 102.1(HP)
    you have no LP available in the DRPA
    read the FAQ \"welcome\" and if possible the http://www.driverack.com/drug/index.asp
    Tutorials...
    do a gain structure
    use the amp controls to balance the system
    try and get as much headroom as possible
    the limiters are not brick wall but functional.. auto produces artifacts.. follow the Welcome setup...
    set up one stack outside if possible and get a flat system and store that for reference.. if indoor is all you have use close proximity on axis mic position to limit off axis signal from reaching the mic... 1 stack only!
    select the flat preset and sweeten to taste if feedback, and room interaction are not a problem, store this as another preset
    gotta fly
  • DraDra Posts: 3,777
    Welcome. We've all bought stuff, then said Oh crap. Such is life.
    Read this post. Your same speakers used (JRX125). http://www.dbxpro.com/forum/viewtopic.php?t=611
    Super long, but useful.
    1) Yes, but... 176hz seems high. (way high)
    2) Yes, but... you are severly under powered. Whatever you do don't let the amps clip. Read the FAQ post. Bridge the 1850. That will give you 1800w @ 4ohms. Each sub would have 900w to play with. that would be a 2 x 3 set-up. (stereo tops and mono sub)
    3) Good choice.
    4) See #2
    6) Patience
    Download the GUI from here http://www.dbxpro.com/Download/ DriveWare® GUI
    220i, 240, 241, 260, 442, 480, 481, 482
    It will help you visualize more what's going on in the DRPA.
    Good luck.
  • dangrdangr Posts: 24
    I am enlightened. Thank you!
  • kpippenkpippen Posts: 551
    I hope to be...some day...:?
    Atkin's, grapefruit, starvation... are but a few ways, but should accompany exersize.
    Hmmm..
    Dra I have to say here that you DEFIANTLY have NOT seen the lite... :idea:
    en-lightened... :idea: a light goes on as the answers fall into place
    en-lite-ned ...enabled to become of less weight.. :shock:
    This is one of those all purpose words though so I guess I have to cut you some slack...I mean a word that can at once indicate illumination AND a weight condition with NO syntax change... No wonder the world wants to kick our ass... :?
    I hope our govt. is being extra vigilant as Sept 11 approaches...I bet they would just love to add an exclamation point to that day...
    Be well,
  • You pups want to be enlightened?... Last time I shared my unvaluable knowledge I got no respect!...:x
    Happy Trails,
    Gadgit
    I'm at a loss. I don't know what to say. If Fred Astare (sp) had 2 left feet, would he then have a yard? I bet Gadgit knows.
  • Monkey boy,...Anyone would know that if he still had his right foot he would have a yard!...:roll:
    Here's one for you: If a jet airliner crashed dead smack on the Kentucky - Tennessee boarder where would they bury the survivors?...
    Gadgit
    They wouldn't bury them at all. They would be cremated. So there! :roll:
  • Excuse me Dra,... He said SURVIVORS!...:roll:
  • Monkey boy,...you just lost the hidden immunity idol...:wink:
    Happy Trails,
    Gadgit
    Wow, now here's a conversation I'm just itchin to get involved in...
    :roll:
    Dangr.. sorry these ner-do-wells have hijacked you thread...Say the word and I'll fry em up in butter and serve em up with hollandaise sauce..
    Gadget,...You have a rash or something?...:oops:
    Gadgette
    I know you said survivors. You also said Tennesee. Weieieieiieeeeeeiee! :shock:
    Dra,
    Thought you might find this interesting...http://www.speakerplans.com/forum/forum_posts.asp?TID=11477
    Kev
    Glad to to lighten things up with my first post. Did the gain structure procedure etc. all is good to go. The only advice that I'm concerned about is putting 900 watts to 200 rms. The subs are 400 watts program 360 to each is 1.8 times rated rms.
    That is not a problem. If you are still concerned, lower the threshhold on the limiters.
