Need help for the new bar setup, please
Hello, just started working in a new bar doing karaoke.
Here is the equipment that is there: 1- qsc 1450 running 2 yamaha c115v's
1- qsc 2450 running 1 yamaha sw218 sub bridged
I have the drpa and need some help on what settings to adjust.
Thank you
Thank you
Sub: Hi-Pass (Lo-cut) 35 - 40 hz / BW 18
Lo-Pass (Hi-cut) 100 hz / LR 24
Tops: Hi-Pass (Lo-cut) 100 hz / LR 34
Gain: Sub: -6.6 db 1 channel stereo mode
-13 db bridge mode
Tops: -0- db
I just looked in the manual and your speakers and amps are in the wizard, so it will set x-over and limiters for you. However I would bring the x-over point up to 100 at least (maybe as high as 125).
