Filter selection
I set up through the wizard and im not using The sub synthesizer. I have a lector gig coming up and would like to change the filter to Feed back limiter. Do I have to run wizard again or can I change it without loosen all my parametric EQ settings and every thing else. I never use the sub syn and i all ready have 6 different venues saved and dont want to lose the settings, just change the fillter.
2 things to consider for a lector.
1) Notch filter (only if needed)- after ringing the system, you can duplicate the more narrow AFS pulled out frequencies and duplicate them in the Notch filter. Clear the AFS and re-ring (squeal).
2) AGC (auto gain control) - Could be useful in a speaking only environment to raise or lower volume if needed if you walked away. I would not go with it on the fly though. Play with it while setting up to see if there are problems with feedback or noise.
PS - the above does not apply if you meant Hannibal Lector. 8)
I am only using the 260 on FOH Would it be okay to run The AFS on live and auto? I dont have much experience with a AFS. I have and still do use a seperate EQ for the monitors.
Good luck, and let us know what you end up doing, how it went, and what you learned.
DRA[/u]
gadget
Now THATS funny!
My baseline set was done in an open feild and then i match the PEQ till there was little adjustments on the auto EQ after i shot the speakers. is it possible to get it flat. is that the goal to run from baseline setting.
This is the first time i did not pink noise at 20db is that what you mean buy set to the volume i was runnig at.
