Should I use a Bose speaker EQ plus DRPA in my setup
Fanman20
Greetings all
I have a small system
Spirit folio desk
Austraila monitor 1k2 amp
EV SX 300 speakers as top boxes
Bose 502 subs as Subs
1 side of amp drives the SX300 the other side drives the Bose Subs ( I know it is under power but is loud enough for my use)
I aquired the subs for free because they were used in an outdoor instillation and birds used the ports as nesting box.
Please no bagging the Bose they do work well and it's all that I can afford
My question is
Should I use the Bose 502 EQ as well as the DRPA ??
Does the DRPA eq the sub as good as the Bose EQ ??
The set up would be
Mixer
DRPA
High otput to amp then SX300
Low output to Bose EQ then amp then Bose subs
Spirit folio desk
My question is
The set up would be
Mixer
DRPA
I recommend ommiting the BOSE EQ and only using the DRPA... If used this should allow the DriveRack to perform the AutoEQ properly...
Kevin
I thought that the bose EQ would only be a modified 1/3 octive eq
therefore no different to the DRPA
What about the cross over point then?
now that I omit the bose EQ I will need to cross them
I will try to find some specs on the speakers and get back to you
Thanks again
Bose 502b subs
Frequency range:
55Hz to 150Hz
EV SX300
Frequency range (-3dB): 60Hz - 20 kHz
Frequency range (-10dB): 50Hz - 20kHz
The frequency response is 55Hz-150Hz if they are the Panaray® 502® B Bass Loudspeaker...
Crossover for Subs: HPF 60Hz - BW18dB/Oct, +3dB gain, LPF 105Hz - L-R24dB/Oct
Crossover for Tops: HPF 108Hz - L-R24dB/Oct, 0dB gain, LPF OUT
Kevin
I will have a play.
Mark
Can I run the system in mono (only left input) and mono out split (Left high + Left low)??
I seem only to be able to program mono input and (L + R high output) and (Left low output)
Should I just not connect the R high output??
From a old man struggling with new technolgy
Yes, if that's what you want.
