Everybody Download DR260 GUI and follow Gain structure Instr
Followed your links on welcome page and spent a couple of days reading the material. Then I downloaded the DR260 GUI and found the xover and PEQ setting for my JRX speakers. Down loaded the applicable pink noise file and burned it to a CD. Performed the gain structure set up instructions and found I needed to adjust the xover gain for the tops to keep the DRPA from clipping on the output channel (dropped the gain 1db) finished gain structure setup by adjusting the power amp attenuators as specified in the gain structure instructions. Loaded the PEQ settings from the DR 260 after the enlightening auto EQ / GEQ discussion we had earlier on the site and… “Zap� the system is performing as I expected it should when I bought it. In particular the DRPA is doing what I wanted it to do with single rack space unit.
I am sure more tweaking will come but just taking the time to read thru the material provided then following your basic gain structure setup instructions in conjunction with the downloaded pink noise file from your link and using the initial xover and PEQ settings for the JRX speakers found in the DR 260 GUI has really made operating my PA system so much better. I can here the color of the music and have excellent response with the ability to use the full available power of the amps. Hey it really kicks now… Just like it’s suppose to do. Thanks for the solid info and guidance.
I’ll keep fine tuning…you guys keep talking!
It's good to hear the success stories! I am sure you will be able to improve on the success you have already achieved. I have poured over the net for years looking for the best info to help others learn and achieve. It has helped me as well as I work through the issues people have.
BE well, rock on!
Gary
