Driverack PA with PEAVEY SP-1s & 118s HELP!
Here is what I have....
pair of peavey SP-1s for tops
pair of peavey sp-118s for bottoms
Driverack PA
1 crown CE1000 for the highs
1 crown CE1000 for the mids
1 crown CE2000 for the lows
Attempting to go three way sending the highs and mids on speakon cable to the tops out of the CE1000s
Highs and Mids are all screwed up
Vocals getting buried in the mix
I think the crossover settings are the problem
Should I even try the three way set up with what I have?
Should I go two way?
Please HELP!
Driverack PA
Please HELP!
For you to bi-amp the SP1's you will need an RTA mic to tune the sytem properly. If you do not, or until you get one, you should run them passive. In the mean time go to the 1st section of the forum and read all the posts there.
Good luck.
And as he states read up.
The Sp-1s have a Biamp mode with the use of the Speakon cable.
Is it possible to send the Highs and mids to the top speaker and the lows to the Sp-118s? We are attempting this now...but I think we have something set wrong within the DRPA. Any guidance with this?
1. Bridge the CE 2000 use 1+ and 2+ on the amp end of the speakon cable...mark it AMP end sub, on the other end 1+ and 1- and you'll need a 1+ 1- (both ends )jumper cable you will use only the channel \"A\" /left input the other is set to -0- or off...
2. For the tops, on the speaker end:
1+ and 1- to the woofer and 2+ and 2- to the Horn. This is accomplished by using a 4 wire cable, or 2, 2 wire runs of cable. See this web site:
http://www.neutrik.com/client/neutrik/m ... 103905.pdf
On the amp end, the 1+ and 1- wires need to go to the 1+and 1- outs of the crown amp (CE1000) that is designated Mids amp... So thats left 15\" to channel A /Left CE 1000, and the same for Right 15\" channel B/Right (CE 1000 mids amp)
The Left horn wire run will hook up to the CE1000 designated Hi's amp, left out and will also be hooked to the 1+and 1- of the amp... follow this for the Right channel as well.
This is then a 2X5 setup and in the wizard and you will set up as such.
DRPA:
Hi outs Left and Right to the CE1000 amp designated Hi outs
Mid outs L&R go to the CE 1000 designated Mid outs
and the Left MONO out of the DRPA goes to the Bridged CE2000
Note ... the CE1000 on the horns is overkill... but the other amps are UNDER powered...follow my setup post for the rest of the setup..
I have to be able to do it with only ONE cable coming from the amps to the top speakers.
Thanks to all who helped with getting me on my way again.
