DRPA with Bose speakers - Please advice
ChrisLeo
First off, Hi guys. I'm new to this site & i have found heaps of help already. To get to the point, Please give me your expert advice on how I should connect my speaker setup. I usually use the system in Biamped mode for large venues & single for smaller.
Mixer - Soundcraft MPX20
Amps - Crown CSL1400
Peavey CS1000
Speakers - Bose 802 Ser 11 x 4
Bose 302 subs x 2
Bose 802C control units x 2
Mackie SRM450 x 2 (usually used for on stage monitoring)
2nd question, whats the difference between a Fixed filter & a Live filter?
Thanks heaps,
Chris
Peavey CS1000
Bose 302 subs x 2
Thanks heaps,
Chris
You posted this in the DRPA section, said nothing about a Driverack, have 2 Bose controllers? are you wanting to replace the Bose controller, add the DRPA and use both? Or what?
A fixed filter is one that has captured a feedback frequency and holds it... a roaming filter is just that.. it looks for feedback kills it and holds for the period you set the filter to hold, then releases and starts looking again...
Yes, I have just purchased a DRPA. Would be perfect if I can go straight from the DRPA to Bose Hi & Low amps, if not I can go through the Bose control units. My question is this.
The Bose control unit has input from Mixer, Then two outputs, One to 802 Amp & one to 302 amp. I'm sure you understand what I'm talking about. What I was thinking of doing was taking the High outs from the DRPA, into the Bose inout section of control unit & letting the Bose handle the crossover. Is this OK or would the DRPA handle it better? What are the advantages/disatvantages
Happy trails,
Gadgit
:idea: How large a room can a pair of Mackie SRM450's handle when used as highs through the DRPA, with Dynacord powered subs, or any other high powered subs for that matter?? That might be the better option :idea:
As for the scenario using the DRPA as a crossover is possible, but again you would need to do a lot of processing, but I believe I could do it.. The thing is you'll probably notice that without processing the 802's sound nasally and mid rangy. It would be interesting to see what the auto EQ would come up with using the \"new indoor\" method of auto EQ. Might give you some starting points for PEQ's.
As I look at your last response I am wondering if your not perhaps located in England perhaps? Thus the Dynacord reference? If so I'm not sure what is available in your area brand wise that is?
Thanks for your response & looking into helping me out. The SRM450's I own already, & they are the older models. The Bose system as well I have owned for the past 15+ years. I'm in Australia by the way.
We are a cover band, mainly rock pop & reggae. I have used my Bose system for a long time but liked the idea of adding the DBX DRPA on. I'm sure it will make a huge difference used properly.
Where the Dynacord came in, is because I'm looking at geeting a tighter, more powerful bottom end. The bose does give you that but not that low down tight bottom end. The reviews I have read here about Dynacords are huge, hence I'm looking at going down that path. What do you think? I know you guys will propably back your JBL's etc. Also another VERY important factor, I have been offered a pair of Dynacord powered subs SUB800A for a really good price.
