I need some advice
Im planning to add to my system, The DriveRack PA with DBX RTA Mic[
before buy this baby i need know if is compatible whit my actual stuff.
4- jbl JRX125
http://www.jblpro.com/JRX/JRX125.htm
1-MARATHON MA-5050 MA PRO SERIES AMPLIFIER
http://www.marathonaudio.com/mamamaprosea3.html
1-QSC RMX 2450
http://www.qscaudio.com/products/amps/rmx/rmx.htm
2-MARATHON B-18X SINGLE 18\" SUBWOOFER
http://www.marathonaudio.com/bsi18sub.html
Im planing to buy 2 floor monitors too
sorry my english is no perfect
4- jbl JRX125
1-QSC RMX 2450
\"spend some extra bucks and get the DR 260\"
\"it is soooo much better\"
Mark
P.S. One draw back with the 260 is that is a bit harder to learn
Certainly it would work for you.. and quite well I might add... If you want to run Mono you could even control the PA AND the monitors which you could not with the DRPA.
To answer your original question...Yes, either will work with your gear. Read all you can on this and the former forum lin above. Talk to someone in your area that has one.
So it's ok if i use the marathon amp to power the 4 jbl's in parallel mode
and use the qsc amp to power my subs using the amp in bridge mode
I go too use the PA dbx unit
Thanks again
