Which DR is right for me??
Hi-
First off, the tech in the DR is amazing, and possibly way more than i need. basically, I am looking to improve my stereo/ surround system with mainly the xo for mains and sub, as well as the auto eq.
Mains are magnepan 1.6, which currently are not bi-amped, but will be in the future. this is where the DR comes in.
Is the DR the most effective way to set the crossover for the mains and integrate the sub? (ACI Titan II)
I have no pro audio experience, and a lot of the terms on here are new, but i think i can pick up enough to get the basics down.
Is the DRPA the right product for me? is the 260 better suited?
or is the eq built into my receiver good enough? (marantz 7001/Audyssey )
(i know it wont do the main xo)
roland
roland
The DRPA should be more than sufficient for what your trying to do... If you were planing on using it for DJing or live music then the DR260 is the way to go...
Cheers!
Kev
How do you like those Magnapans? I always wanted a set, or two. My friend had the Tympani series for fronts, and the MGII's for backs and a set of Infinity subs, Conrad Johnson amps... ams did that thing sound amazing...I have the Infinity RSII speakers and they sound awesome, but I would still like to have a set of those...
gadget
I've read that biamp w/ active line level XO is another big step up. I want to do it \"right\" and if the 260 will deliver audible improvements, i will prob go that route. the pc manipulation is a plus.
I dont want to ask a lot of basic questions - is there a faq that descibes PEQ and other newbie questions on this stuff? thanks.
http://www.dbxpro.com/Forum/viewtopic.php?t=958
http://www.dbxpro.com/Forum/viewtopic.php?t=959
http://www.dbxpro.com/Forum/viewforum.php?f=60
And then check-out Training Modules...
http://www.dbxpro.com/Download/
Cheers!
Kev
http://c-eye.net/flash/WalkenCowbellSB.html
http://www.funnyhub.com/videos/pages/vi ... wbell.html
Kev
thanks again.
more COWBELL!!.
http://www.youtube.com/watch?v=g-AdxjDGioc&NR=1
specifically, 1) is the unit "transparent" enought to use for home theater/ music listening,and
2) does the auto speaker setting and room eq work well enough for same use?
thanks again all.
Roland
I wish they would release the algorithm as a 260 upgrade! It's that good... They also added mute buttons per output, which is nice...
Yes the DRPA would work great for your system, but the 260 still has the majority of the features that make it the best choice..
I looking at this again because of the PA plus model.
I have just bought a new pre-amp, which does not include audesssey room correction, and wanted to see if the PA would fit the bill and allow a consolidated xo with room correction.
I know the 260 is a better choice in terms of control and options, which is why i may still go that route. however, i wanted some advice re: does the "plus" upgrade make the PA suitable for home theater use as an xo?
thanks again.
Dennis
Ya I think the new DRPA+ is a significant upgrade to the DRPA... It's quieter, the auto eq is better sounding, and massively fast, but you will need the measurement mic as well...but I figure it will make you smile... far more than a fixed analog crossover would...so many cool tools to manipulate the system..
thanks.
Dennis
Dennis
thanks again. newbie to pro audio gear here..
Dennis, why not measure a couple of common setups in SMAART and tell us what you find...I didn't realize we disagreed on that :? The only info I have is that Mikey measured the LR24 and got 7.4 something like that ms from high to low in a 2x4 on the 260...other than that no "base" was ever set forth other than what I read on the PSW and that was about .5 ms (still looking for the thread...)
any way if the receiver has delay you should (jn theory) be able to align the system...
After you explained more, it turned out that Mikey's test was a little more complex than mine and also frequency dependent. I don't understand completely how he conducted the test so I can't reproduce it.
If all the speakers were aimed the same direction, that would be true. With the rear speakers aimed toward the front speakers, it throws a big monkey wrench into the alignment process. I feel the only reason surround sound works is that there is totally different information fed to the rear speakers than the front ones and alignment is not crucial.
Dennis
