Need clarification on gain structure
Hi all
Thanks for all the wonderfull information on this forum.
I've read through as much as I could. I think that I understand the gain structure procedures. Now, when you use the wizard on the DRPA, it shows a recommended \"amp level setting\". A similar setting shows up in the DriveWare GUI. I understand that it is best to leave this setting at the recommended value and finish the wizard, then do a gain structure as outlined on this forum. After that, I arrive at a point where my amp attenuators are at a certain level. Do I then go back and edit the configuration and adjust the \"amp level settings\" on the DRPA to match the physical amp attenuator values? Furthermore, can someone please explain to me what exactly this \"amp level setting\" does in the DRPA software?
Regards
Laure le Roux
Regards
Laure le Roux
Personally I think the "wizard" creates more chaos than it's worth...
Cheers!
Kev
