How to Unlocked Driverack PA
Recently I am buying dbx Driverack PA.I am very new to this even i dont know how to oprat driverakc pa.i just sawing the button and pres that.and my display message locked.and than system button not working.when pres button display message locked.so how can i unlocked driverack pa.[/b]
All Power-Up Functions require a button(s) to be pressed and held as the unit power is turned on.
DriveRack 260 Power-Up Button Functions
System Lock Out
• Press and hold <RTA> at power-up until one of the following messages appears: System Unlocked All user input will be accepted or System Locked No user input will be accepted • Rotating the <DATA> wheel to select either Lock, Unlock or Filter Unlocked the system. • Pressing <PREV PAGE> will unlock the system if it were locked or it will lock the system if it were unlocked. • If you wish to leave the system locked with the exception of being able to clear the feedback filters, follow the same procedure on power up and then rotate the <DATA> wheel to select the feedback filter unlock feature. • Pressing any other button will abort the System Lockout sequence and the unit will reset normally.
If that doesn't work try a soft reset and if that doesn't work try the hard reset... Be advised that the hard reset will erase the user program and reset the unit to \"factory defaults\"...In the event that a reset is required, the DriveRack™ 260 offers you the option of performing a “Soft� or “Hard� reset. The Soft Reset resets all operating parameters except user programs. The Hard Reset Procedure will reset all programmable information back to the factory defaults.
System (“SOFT�) Reset
• Press and hold the <UTILITY> button at power-up until the following message appears: “! SOFT RESET?� “Yes <PREV PAGE>� “No <PROGRAM>� • Pressing the <PREV PAGE> button will start a System Reset (All Utility settings will be defaulted.) • Pressing the <PROGRAM> button will abort the System Reset sequence and the unit will reset normally.
Factory (“HARD�) ResetPress and hold the <STORE> button at power-up until the following message appears: “! HARD RESET?� “Yes <PREV PAGE>� “No <PROGRAM>� • Pressing the <PREV PAGE> button will start a Factory Reset (All User Programs will become copies of the Factory Programs, all Utility settings will be defaulted, and all Security settings will be defaulted). • Pressing the <PROGRAM> button will abort the Factory Reset sequence and the unit will reset normally.
Good luck!
Kev
Sorry for the confusion!... Here are power-up functions for the DriveRack PA...
DriveRack PA Power-Up Button Functions
System Lock Out
• Press and hold <WIZARD> at power-up until one of the following messages appears: System Unlocked All user input will be accepted or System Locked No user input will be accepted • Rotating the <DATA> wheel to select either Lock, Unlock or Filter Unlocked the system. • Pressing <PREV PAGE> will unlock the system if it were locked or it will lock the system if it were unlocked. • If you wish to leave the system locked with the exception of being able to clear the feedback filters, follow the same procedure on power up and then rotate the <DATA> wheel to select the feedback filter unlock feature. • Pressing any other button will abort the System Lockout sequence and the unit will reset normally.
If that doesn't work try a soft reset and if that doesn't work try the hard reset... Be advised that the hard reset will erase the user program and reset the unit to \"factory defaults\"...In the event that a reset is required, the DriveRack® PA offers you the option of performing a “Softâ€? or “Hardâ€? reset. The Soft Reset resets all operating parameters except user programs. The Hard Reset Procedure will reset all programmable information back to the factory defaults.
Cheers!Kev
High: SRV
Medium: Hendrix
use the following proceedure:
System Lock Out
. Press and hold < WIZARD> at power up until one of the following messages appears:
STSYEM UNLOCK All user inputs will be accepted
Or
SYSTEM LOCKED NO user input will be accepted
. Rotating the <DATA> wheel to select either Lock, Unlock or Filter Unlocked the system.
. Pressing the <PREV PAGE> will unlock the system if it were locked or it will lock the system if it were unlocked.
. If you wish to leave the system locked with the exception with the exception of being able to clear the feedback filters, follow the same procedure on startup and then rotate the <DATA> wheel to select the feedback filter unlock feature.
. Pressing any other button will abort the system lockout sequence and the unit will reset normally.
