Ok...lets see if this tricks anyone
DJ Steel
I just purchased a DBX Driverack PA. I have a QSC RMX2450 amp, and a Peavey 1.3K amp. I have 2 Cerwin Vega INT252 dual 15 horns, and 2 Peavey DTH S4 dual 15 horns. It doesn't describe how to hook these up.
Help!??
Help!??
Unfortunately there is no master hook-up manual...
Seriously,...the manuals for your amps, speakers, and DriveRack combined should give you more than enough information regarding the \"hook-up\" of your equipment... If you don't have the manual for a specific piece of your equipment it should be easy to find and to download off the web...
Cheers!
Kev
Steel, the DRPA hooks up to the amps and the amps hook up to speakers.
Sorry couldn't help it.
Set up a CUSTOM 2 x 3 or 2 x 4 set-up. As Kevin suggests use the manuals with your gear to help you set the x-over filters.
Guessing somewhere around 40 - 50hz (BW18) & 90 - 120hz (LR24) for the subs and 90 - 120 hz (LR 24) for the tops. Put the more powerful amp on the subs.
Read the entire READ ME FIRST section. If you don't, you'll probably want to sell the DRPA for 10 cents on the dollar after your first gig.
You have not made a mistake in getting one. But you DO have to know how to use it. READ READ READ!
Sorry guys,
PS - I have a ser #45J34 speaker and a #K23L0OP amp. What should I do with them. The speaker has small holes on the back and the amp has red & black things. How do I connect them? By the way I'm in Tibet and do DJ'ing for Yehti family reunions.
This why I posted (master hook-up manual) to see what kind of response I would get...
I wasn't going to waste my time on this one...
Kev
Mr. DJ use one or the other... not both, if you do that we can help , if no your on your own...your choice...and if you want to biamp them, we'll need all the info on the speakers, and their components... and the amps...otherwise read up and learn why theses will not play nice together...
Moderator...
