PV118 Subs Question
What should I need from these specs to help setup my 2-Subs correctly with my Peavey 115HCII's??
PV118 Subwoofer (1x18 in.) Features
• Vented bass subwoofer enclosure
• Pro Eighteen 18 inch premium woofer
• Optimized internal low-pass crossover network
• Pole mount adapter
• 400 Watts program power handling
• 40 Hz - 180 Hz (+/- 3dB)
• 95 dB at 1W/1m
• 8 Ohms
• Dado jointed 3/4 inch MDF construction
• Heavy-duty, powder-coated metal grille
• Technical Description
• Frequency Range (-10 dB, half space): 38 Hz to 500 Hz
• Frequency Response (+/- 3 dB anechoic): 40 Hz to 180 Hz
• Sensitivity (1 Watt/1 meter): 95 dB
• Power Rating (program): 400 Watts
• Peak Power Capacity: 800 Watts
• Maximum SPL: 118 dB
• Transducer Complement: 18� Heavy duty woofer with 3� voice coil and 65 oz. magnet
• Box Tuning Frequency: Low frequency section: 46 Hz
• Recommended Infrasonic Filter Frequency: 40 Hz, at a minimum of 18 dB/octave roll-off
• Recommended Crossover Frequency: 150 Hz or less
• Nominal Impedance (Z): 8 Ohms Input Connections: Two 1/4\" phone jacks in parallel
• Enclosure Materials and Finish: MDF covered in black carpet
• Dimensions (H x W x L): 27.00 x 21.88 x 19.63 in.
• Weight: 73 lbs.
• 95 dB at 1W/1m
• 8 Ohms
• Weight: 73 lbs.
HPF BW18@45Hz
LPF LR24@105Hz
Gain +3dB
TOPS:
HPF LR24@108-114Hz
Gain 0dB
I think Dra is working with you on your other thread so I would listen to his suggestions since he's considering your entire setup...:)
Kev
Those settings should do fine,...but only as a starting point... Set your gain structure as outlined in the middle of this post...
Cheers!
Kev
PS. Listen to Dra if he suggest otherwise... He's lots more knowledgeable on the DRPA than I...and he's more up-to-speed with your setup...
@Dra
I thought there was no LPF for tops in the DRPA?... I thought it was \"out\" by default?...
Kev
Of course if you were looking at the GUI thats the 260 and of course that HAS an LPF for all outputs...
Thanks!... Makes perfect sense...:D
Kev
High outs have no Lo Pass (high cut) filter, but have 3 PEQ filters.
Mid outs have a Lo Pass filter, but only have 2 PEQ filters.
Choices, choices.
If your top cabs have more peaks and/or dips that need fixing to achieve near flatness, go with the High outs. If not and you wish to limit the exteme upper output, then go with the Mid outs.
I doubt you will need to limit extreme highs... It's simplistic...plus you'll get the extra PEQ which will be more beneficial...
Cheers!
Kev
