RTA and the speakers ability to “throw� the sound
When auto eq’ing using the outdoor method you state that we should place the mic 8 – 10 feet away. This will “flatteren� the amp and the speakers response to the pink noise created by the Driverack .
In the garage you used the near /far response the far response was also only a few feet away.
Have you done any testing on the speakers ability to “throw� the sound. The difference between horn loaded and cone loaded speakers.?
When I do an outdoor gig I am generally around 100 feet away from stage. What would the difference be in the driveracks RTA response at 100 feet apposed to 8 – 10 feet away??? (on a still day)
So, Question
When we auto eq we take in the amps response , the speakers response but not the ability of the speak to “throw� all frequency at the same level any distance. Why is that.? Not all speakers have the same throw ability.
We want the best sound we can have at 100 feet not 8 feet.
So, Question
Is the only element that \"should\" change / decrease when moving further away be the SPL?? (in an open field)
Interesting!
Mark
I have found out that at \"25C and 50% RH you have about 8dB per 30m of excess attenuation at 8kHz. So HF rolls off with increasing distance because the air absorbs it.\"
So would that indicate that we should eq at 30m or where ever the largest crowd is? (out doors)
I dont understand. Please explain.
Why do these things matter?
speakers in or out of phase, (you can check visually and/or use 9-volt battery)
Time / delay can be measured
Mark
Our focus here has been and will be to go to any given performance with a properly tuned system the hallmarks of which are, proper component phase, which means:
1. That with a positive building wave form all components react in the same direction be it away from, or toward the baffles that form the front of the cabinet. (most speakers exhibit an outward motion for a positive pulse, JBL however has reverse wound some components) Phase coherence however is beyond the scope of the Driverack, or it's measurement systems...
other mitigating factors include:
2. Components are delayed properly by either physical relation to each other or delay in the crossover or processor. Note here also that digital artifacts exist in the form of delay through the crossover...those can be measured, but again are beyond the scope of this forum. Mike Kovach has measured the delay of the LR 24 and found it to be about 7.5 ms, other processors have also been measured in the 5-7 ms area, so that is a real factor here.
3. That they reproduce all frequencies within the abilities of the drivers with equal \"LOUDNESS\" limited by the accuracy of the 28 band RTA or the ears of the system tech.
The throw characteristics of the speakers and the limitations of the propagation characteristics are beyond the scope of these discussions and should be addressed on a forum such as SMAART where those characteristics can be accurately and cogently measured and dealt with.
superb the next
I keep well out of politics and steer clear of the news (all doom and gloom)
I live on 200 acres of land in the bush on a conference centre site.
Similar to your summer camps but we average 200 people a day
I’m approaching 50 and unashamedly chasing life style
Can give you web site in a PM if you would like
Keep up your good work.
Mark
