Home dbx User Forum dbx Archive Threads DriverRack PA & DriveRack PA+ PA Connectivity
driverack pa for monitors
rmbrmb Posts: 7
edited February 2008 in PA Connectivity
If set to a 3 way can the mid x over be set like the high for extra monitor sends and use the high and mid outs for main monitors and the low to ad a sub for the drummer?
  • GadgetGadget Posts: 4,915
    Yes, you won't have individual control of everything like the 260 does, but yes...set each as a bandpass filter, which just means drag the HPF down to where you want the speakers response to stop.
  • rmbrmb Posts: 7
    Thanks, I have been using a DR PA for the mains for several years now and just picked up a used one for $250.00 for the monitors.It helps clean up the rack a bit.
  • DraDra Posts: 3,777
    RMB,
    It is very refreshing to get your kind of question. Presenting a solution to your problem then asking for confirmation and guidance. Way to go.
