2ohm or so loads
rmb
Any recommendations on running 5, 8 ohm monitors from one QSC MXA 2000 amplifier? One side would be running a different load than the other.
Monitors are a combination of 12inch JBL and 15inch EAW.In the QSC manual the amp is rated for 2 ohm use . I always try to stay on the safe side.
((8+5)/2)/2 =
(13/2)/2 =
6.5/2 =
3.25 ohms
A 5 Ohm cabinet?
Cheers!
Kev
I think they are saying five 8-ohm monitors... So I would recommend three on one channel and two on the other...
Kev
Ahhhhhhhh! Bach! (You get that one, K?)
Kevin is right.
3 cabs = 2.7
2 cabs = 4
As the spec sheet indicates the amp has ~1000w @2 ohms.
So... with the idea that one wants decent headroom on any given channel, the more speakers you add, the less power you will have for each individual speaker.
With the QSC's ratings in mind and an 8ohm monitor, 1 monitor gives 450W, 2 gives 325W each, and 4 gives 250W each.
The amp may be able to produce more power as the load increases, but your headroom will decrease and so will your max volume.
When the smoke is released, It's awful hard to get it back in...
Speakers in parrell
Speaker A impedance 8 ohms
Speaker B impedance 8 ohms
Total impedance 4 ohms
Speaker C impedance 8 ohms
Total impedance 2.666666667 ohms
Speaker D impedance 8 ohms
Total impedance 2 ohms
Calculations
1/(1/speaker 1 impedance + 1/speaker 2 impedance + 1/speaker 3 impedance )
1/(1/8 + 1/8 + 1/8 )
1/(3/8 )
1/0.375
2.666666666666
Try Duncan's calculator
http://www.duncanamps.com/technical/impedance.html
Kev will like it
Mark
P.S. bones442 is \"dead\" right when he says \"When the smoke is released, It's awful hard to get it back in...\"
5 x 8 ohm speakers on 1 side of amp =
1/(1/speaker 1 impedance + 1/speaker 2 impedance + 1/speaker 3 impedance + 1/speaker 4 impedance + 1/speaker 5 impedance)
= 1/(1/8 + 1/8 + 1/ 8 + 1/8 + 1/8 )
= 1/(5/8 )
= 1/0.625
= the smoke gets out!!! :shock:
1.6 ohms
I have done this - three 8ohm wedges on 1 channel and two on the other - with a QSC MX1500a and even a QSC USA900 (which isnt even rated for 2 ohm loads) and had no problems with the "smoke gettin out" but only when I couldnt convince the musicians that 4 wedges would be better than 5.
As others have said, you need to make sure that you leave yourself enough power. The amp will put out more power with three 8 ohm wedges because of the lower overall load but the power is now being split across 3 wedges instead of 2 so each 1 probably wont get as much as if there were only 2. Even dropping the load in half usually doesnt actually souble the output. In some cases you actually wind up with lower overall SPL.
Gadget...
