Mackie Speakers with Driverack PA
I use the Driverack PA and was wondering if anyone had a better setup than custom for a: Mackie SA1521Z , and SWA1801z setup (both stereo). I was considering the Driverack PX, but I still dont see a preset for them.
Any information on these speakers would help.
Can we choose an already made preset thats close to our speakers
eg For our 1521z we could choose the SRM450
For our SWA1801 we could choose a similar JBL active cab?
Would running through the different presets of other speakers do any harm?
With 15\" tops and plenty of power (watts)you can cross anywhere down to about 75 hz... 90 is probably more realistic...With low power move the crossover point up the lower the power you have...don't exceed about 120 hz or the subs will start to sound honky...
With 12\" and smaller tops with plenty of power check out the speaker s3db down point... thats TOO low.. so generally a start above 100 hz.. and move closer to 120 hz the less power you have..
I usually spec hipass @ around 45-50 hz BW 18
lopass again depending on speaker and power @ LR 24
spread the xover point a few hz and use a hipass of LR 24 for the tops...
those presets are less than useful in my opinion..the wizard is so darn simple to use...then your set for what you have and not some general everything preset...
No doubt more questions on the way when it arrives.
