JBL System Configuration
n_mahendran
Dear ALL,
I am new in this forum. I need help. I have the DRPA but it does not have the parameters for my speaker set-up. The following crossover set-up configuration are required.
1. SR 4726 A (bi-amp mode)
2. SR 4726 A + SR 4719 A (tri-amp mode)
3. SR 4733 A (bi-amp mode)
4. SR 4733 A + SR 4719 A (tri-amp mode)
Is there any method to update the DRPA to cheive the above.
I hope some one would be able to help me out.
Thank you
Mike
Thank you
Mike
Anyway, there are two things that you can do.
In the training module section above, download and install the Driveware GUI software for the 260 and the updater. It will help you \"see\" what you are doing in the DRPA (x-over, PEQ's limiters, etc). For your application, the wizard will recommend x-over points / slopes and PEQ settings for bi-amping the tops.
The other thing is, go to the JBL site and download the PEQ and x-over setting for those cab's / combos.
Personally, I'd do both.
I've already looked at the PEQ's for your cabs and the DRPA does have enough filters in each band, so you good.
PS - I believe that you can send the DRPA back to DBX for an upgrade, but a waste of money in my opinion. If you insist, be sure to contact them for confirmation that your cabs are in there.
The 26 cab needs 2 mid and 2 Hi PEQs. Approx .2 ms delay on the woof.
The 33 cab needs 2 mid and 3 Hi PEQs. Approx .3 ms delay on the woof.
So he should be OK, at least as far as the wizard says. (and I know how much you love the wizard)
Thank you for the feedback.
