Help regarding setup of my DRPA with my rig...
Good day,
My name is Chris. I am from the Philippines
pines.
I have a band who plays classic lite jazz, rnb and dance music in an outdoor park with an area of 120sqm.
Please help me setup my drpa with the right configurations and crossover setup to maximize what i got.
I have:
Soundcraft Mixer EFX12/2
1 pair Beta 3 U15A as my \"High\"
Transducers (Woofer)15LB075-U×1
(Treb)ED4401+H4403
Frequency -3dB / -10dB 40Hz-18KHz, 35Hz-20KHz
Rated Power RMS (Treb)100W, (Woofer)300W
Dispersion (HxV) 50-100°Ã—55°(Rotatable)
Maximum SPL (dB/M) 120dB(Free Field)
Frequencyadjust 100Hz :±12dB / 10KHz :±12dB
Input impedance Balance 20K Unbalance 10K
Connector type mic\\line: XLR J3P / XLR K3P
Protect Circuit Limit Protect overheat protect,Short Circuit protect,HF Protect
1 Beta 3 U15A as my \"Monitor\".
1 Inter M Power amp CM15.5
Power output is
Stereo Rl = 8ohms 510w+510w, Rl = 4ohms 800w+800w
Frequency response rl=8ohms,P=1w 10hz~35khz(+-.5db)
Input impedance = >= 20kohms
Power consumption is 950 watts
1 pair Biema Subwoofer FD181bII
FRequency responce is 30hz-350hz
Impedance = 8ohms
Power(RMS) is 400w
Peak = 800w/5min
sensitivity = 100db(1w/m)
max. spl = 129db
I want to optimize setup according to our bands need.
How do I make the kick drum with more ooomph or low end? Is there a particular trick or twist involved?
Your suggestions will be highly appreciated. Thank you very much.
Chris
pines.
I have:
(Treb)ED4401+H4403
Power output is
Impedance = 8ohms
Power(RMS) is 400w
Peak = 800w/5min
max. spl = 129db
Chris
http://www.dbxpro.com/forum/viewtopic.php?t=1134
AND read the READ ME FIRST SECTION on the first page (all of it).
