dbx 260
OK...Ive really tried to figure this out by reading here and other places, but I cant get this figured out....any help or direction would be GREATLY appreciated!
here is the equiptment we are running...
2 QSC MX 1500 amps running 4 Renkus-Heinz TRC-121/9 speakers
these are connected to output 1 and 2 on the DBX
we also have a crown xti 4000 running 2 18\" subs
these are connected to outputs 3 and 4 on the DBX
outputs 5 and 6 are not used...nothing plugged into them.
My question.....is there a preset program that is suitable to run this?
if the answer is no, would somebody pleeeeeease come up with a configuration for me or help me to make one on my own.
ALSO what should the crown be set at? Its wired up for stereo output.
should I use a quickstart factory preset?
Like DSP off or subsynth???
Subs - HPF @ 40hz BW18 LPF @ 100hz LR24 (up to 120hz or so)
Tops - LPF @ 108hz LR24 (up to 128hz or so) LPF if desired
Post back if you have more specific needs, and welcome.
I'd also just set up a custom 2X3 in the wizard and then do the procedures in the READ ME FIRST BEFORE POSTING.
Im a strip club dj and have always been told...the amps are set dont touch them. that worked for me until a drunk stripper tried to \"fix\" it after she bumped the wheel and the \"display thingy\" started flashing...'
she changed the preset and then loaded it and of course the club went quiet..i was using the facilities...
after she did that it sounded like crap...
i had never taken note of what preset configuration (if any) that we used but I know the one it was loaded on sounded horrible...
ive asked management to get someone out to fix it several times, but i dont see it happening. if they can still hear it, it isnt broken. and they dont need to spend any money. I decided to try to learn enough to get a basic setting worked out...
what I accomplished is using Preset 6 with output 5 and 6 muted.
It sounds much better than it had...
I have the crown xti 4000 set at Sub Synth preset
The levels on the crown are turned up halfway.
the qsc's are up all the way...
using the \"wizard\" however I dont see ANY of the components we have in the lists so Im forced to pick custom on every item.
is there an expanded list or a chart anywhere that lists like items that you can generally use a product that IS on the list to subsitute for?
Once you get the thing set.. and if you intend to EVER relieve yourself again :roll: I'd suggest you read up on the security system...The 260 has multiple levels of security, and it makes a lot of sense to lock out prying strippers :oops: since they usually don't have a LOT of experience with DSP...:-B
The good news is there is no way that she could have modified ANYTHING...without pressing the \"store\" button three times...Even if she was \"bumping and grinding\" with the \"store\" button alone it's also nearly impossible that she modified in any way the program she gave a lap dance to since that would require knowledge of much more than how to \"spin knobs\"...
So I can't imagine the damage is that difficult to fix.
we were posting at the same time
if im not mistaken arent the 50 presets really 1-25, then they repeat?
i mean isnt preset 31 also preset 6?
What subs are they... The XTI 4000 is only 650 watts @ 8 ohms, and 1200 watts @ 4 ohms... both in stereo so even in the Bridged mode 4 ohms is 3200 watts.... most quality subs could handle those numbers..
If you were to read the Welcome ... \"read me before posting \" you could make that system hum right along if you simply follow the steps laid out there...
How do you like those R/H speakers? I like their stuff a lot... but it's pricy...
watching the tutorials...alot to absorb, but with time....
For the short term I have 1 more question though, its an easy one though..
if I do use config 6 (or 31) since nothing is plugged into the 5 or 6 outputs on the DBX I should just mute them correct?
but in this case they make me nervous because they mostly stay solid orange, and I know I dont want the other ones doing that.
Also the bigger dancers hate lights of any kind....
Like any preset with JBL on it sorry.. I digress... \"
Gadget do you dislike JBL's?
hmmm I see they are rated for 800 watts, and in stereo mode the crown does put out only 650....maybe I will take it (the crown xti 4000) off of \"sub synth\" and turn it up to 3/4
You can't hurt those with too much power... but too little.. oh ya...
Gadget...
JBL is second to Bose and Bose SUX!
