Mobile Disco Set Up for best Performance
edward kasuleedward kasule Posts: 2
edited April 2008 in PA Configuration Wizard
I am a mobile disco DJ. I have two Eliminator i Kw Dual 18-inch sub with 1000 watts continuous,4000 watt peak power handling. , A crown XTi 4000 Amplifier, a drive rack PA, 2 Carlsbro Gamma 15/400 Passive Speakers, 2 SXA360 Powered speakers
i want to drive the two Passive speakers on One Amp's channel, and the 2 Subs on the other channel.
How can i best set the Drive Rack PA (EQ,XOR, etc) for my system.
you help will be highly appreciated.
  • DraDra Posts: 3,777
    Mixing 2 different speaker brands / models is bad enough, but mixing powered and passive is another level of bad. Read the READ ME FIRST... section. Good info there. Then come back (if you still need to) and lay out what you wish to accomplish with your set up. How you intend to control and use the system.
  • kpippenkpippen Posts: 551
    Edward,
    Congratulations!... You made it to \"Level Two\" of bad...8)
