using 2 different amps for mains
I am wondering how to configure my pa system or the drpa for this pa setup.
2 - Way
Lows are (2) bridged Carvin DCM2000's (2000W bridged) to a dual 18 sub each.
My question concerns the highs:
Peavey PV 2600 (900W per channel) with a respective 215 w/ horn (Peavey TLS 4X 800W program) - on each channel
Crown CE 1000 (450W per channel) with a respective 215 w/ horn - on each channel
I am planning on sending the dual mono signal to the peavey, out of the thru jacks on that amp and then to the Crown CE 1000. (with dual mono again)
HOW DO I SET THE DRPA to recognize or accept the power and/or linking of my setup for the best AUTO EQ, feeback supression, ETC.
And no i cannot bi-amp my full range speakers, and im not having them rewired.
Thanks in advance
2 - Way
Thanks in advance
Use custom for everything set-up question asked.
Don't use the Auto-EQ (yet)
Read the READ ME FIRST section for Gain set-up and other IMPORTANT info. Then, come back with more specific questions.
But say for example if i AUTO EQ and the driverack is boosting the bass and cutting the highs, then i suppose i should turn up the low amplifiers and/or turn down the high amplifiers and then AUTO EQ again right?
As for as connecting my power amps to the driverack, am i correct in saying the best way to send the highs is to:
RIGHT - run the dual mono signal out of the drpa and to the respective left and right on the pv 2600 and then out of the thru's on each channel to the crown ce1000's respective channel
WRONG - instead of alternatively running an output of the drpa to one power amp and the other output of the drpa to the other power amp.
Even though im running dual mono, i suppose keeping the left and right channels the same throughout the system is less likely to confuse the drpa'a automatic aspects
You also need to provide as much info on the speaker as you can which you would also have found out had you read the FAQ's as requested...
gadget
