DriveRack PX vs DriveRack PA
Hello,
I'm new to this forum, I've read the posts in the Welcome and Faq's section and tried a search, but I've yet to find any info on the DriveRack PX.
I did read the product info on the DBX website. Can anyone tell me if there are any posts on this forum about the PX? Is there post that compares the PX vs PA like the one contrasting the PA and the 260?
Maybe the PX is just to new to have a forum here yet.
Thanks for any info you have
Huh? Maybe it's early or I have a fever and the only prescription is more cowbell, but aren't 2 overlapping bandpass filters a crossover? Please explain.
The Answer only 2 way
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/E ... 81023A.pdf
From Page 28 of manual
page 16
Mark
dbx PX at $399.97
dbx PA at $499.97
dbx 260 at $999.97
The PX looks good for what it does for the price!
Mark
What???
Sorry missing your thoughts on this one.
What is the difference between the
crossover section (dbx PA)
and a
High-Pass and Band-Pass Filter Section (dbx PX)
Which in a 2 x 2 setup is really doing the same thing the the input signal???
Mark
DRPA-
High out - HPF @ 100hz
Lo out - HPF @ 45hz LPF @ 100hz
DRPX-
Gadget -
OK. I just looked at the PX and I'll still call it a cross-over, although (I suppose) it's by the truest definition is a device with filterable outputs. (Just like a cross-over) :roll:
I currently have a DriveRack PA that I use regularly as my primary EQ for my sound system. I use the RTA for setup and have had very good results with it. This unit has become damaged and even though this will make me look like an idiot, I’ll go ahead and explain the damage.
The screen on the unit began to function somewhat erratically. Sometimes it would work fine and other times it would be completely blank. Ok, here’s where my stupidity comes in. When this problem first manifested itself, it was during setup for a live performance. When the screen refused to come ‘on’ I did the only thing I could think of, I tapped on it. Strangely enough, this worked and I was able to use the unit to complete my audio setup.
I know that I should have sent it in for service, but I just didn’t get around to it. I just tapped it whenever necessary. Now to my embarrassment, the screen has become detached and tilted in on one side. It does however work all the time now, LOL.
I plan to get another unit to use before sending this one in for service. Upon visiting the DBX website I learned of the DriveRack PX and that is my reason for the original questions in this thread.
The PX is to be designed for use with powered speakers, and since all of my speakers are powered, I wanted to investigate it further. I did think that it included a crossover since it has stereo or mono subwoofer support (sub outputs and band pass filters consisting of low pass and high pass filters). I am still reading and trying to understand the difference between this and an actual crossover.
If the PX would be a compromise in features that I need, then its not worth the few $$$ that it would save me. My first priority is high quality sound and simple (read fast) setup. We setup in a different location for each performance, mostly churches or small to medium size auditoriums and time is very limited. I must keep to a very quick but effective setup routine.
I’m going to go back and re-read the PX manual a second time to try and get a handle on the differences between it and the PA that I already own. On the DriveRack PX product page, DBX states, “ In another dbx industry first, we’ve created a processor specifically tailored for powered speakers�. My question is, “Will the PX be a more appropriate choice for a system with powered speakers than the PA, or even the 260?�
Thanks again for your help, you are appreciated
Richard
I wish I knew if the PX had the hiss of the DRPA...If not it might truely be a better solution since it now sports the peak plus limiter. It has all the other features including all the different slopes that make a \"crossover\". I think that the whole flap here is simply a matter of the fact that this is a powered speaker controller, otherwise all the features of a 2x4 CROSSOVER are there.
You have
Stereo Feedback Elimination with 12 feedback notch filters
Dual 28-band Graphic EQ
Classic dbx® Compressor
120A Subharmonic Synthesizer
Stereo Multi-band Parametric EQ
Stereo PeakStopPlusâ„¢ Limiters
Pink Noise Generator
Auto-EQ with 28-Band RTA
dbx M2 Measurement Mic and zippered pouch included
You can sell the mic on ebay and recoup some more money, as you already have one)
How much would a Dual 28-band Graphic EQ cost you if you went with individual equipment ???
“Bang for you buck�, need a simple bit of gear, set and forget bit of gear, than I think it is worth it.
Get the dbx PA fixed and put it on your foldbacks!
Good luck
Keep us informed
PS
dbx PX at $399.97 - $99 for DBX RTA MIC (recoup on ebay) =
$299 That's cheep
I suppose they did this as there are very few active folded horn subs
where you would need the delay.
PLEASE :!: :!: :!: :!: :!: :!: :!: :!: :!: :!:
READ ME FIRST BEFORE POSTING :!: :!: :!: :!: :!: :!: :!: section...check it out BEFORE you post again!!!!!
moderator...
