specific crossover settings
dew
Hello, im wondering what setting my crossover to, specifically the slopes, I dont know which db of slope to use, also linkwitz-riley or bw.
Heres my setup:
2-way
Lows:
(2) Carvin DCM2000 - 2000W @ 4 ohms bridged
(2) Carvin Dual 18\" subs
http://www.carvinworld.com/manuals/SW1802_DATASHEET.pdf
Highs:
(1) Peavey PV 2600 - 900W channel
1 pair of Peavey TLS4-X (215 cabs w/ horn) - 800W program
http://peavey.com/support/searchmanuals/list/tls4x_specs.cfm
(1) Crown CE 1000 - 450W channel
1 pair of Peavey TLS4 (215 cabs w/ horn) - I do not know the rated power of these 2 cabs, but THEY ARE DIFFERENT from the other cabs mentioned, and i believe that they dont need as much power as the other cabs. (This set of cabs and amplifier were recommended as a match when we bought them at the music store). Most Crowns are made to have some built in headroom right? But thats irrelevant, that is what I have.
The Carvin DCM2000's are bridged powering a dual sub each.
Highs are sent out of the drpa to the Peavey 2600 and then onto the Crown CE1000. Cabs are on their own channel on a power amp.
After setting the limiters, i left the crossover at 100hz and surprisingly found that the sound is well balanced having all the power amps' attenuators at their maximum setting for the limiters to be effective. (When i Auto EQ, the equalizer is basically minutely boosting and cutting alternating frequencies.) I believe that I just left the slope on what it was set; BW 6 for lows and LR 12 for highs.
I switched to Response A, and i'm very happy with the sound. But it could probably sound better and Ill never know unless I get it set more precise.
I believe I'll leave the crossover point at 100hz. But I'm open for suggestions. I'M MORE CONCERNED ABOUT THE SLOPE . THAT IS WHAT I'D LIKE A RECOMMENDATION FOR.
Also settings for the Alignment Delay, if thats relevant to my system. I place the 2 left cabs on top of the left subwoofer, same on right side.
My last question is about the PEQ. What would this be used for, and what does the BELL, L SHELF, H SHELF etc. mean?
Dew
Heres my setup:
2-way
Lows:
Highs:
Dew
Have a read of this whist waiting for the boys to reply.
http://www.lenardaudio.com/education/06_x-over.html
Very helpfull
Mark
X-over point between tops and subs should be LR-24.
Hi pass (low cut) for subs should be BW-18 (40-50hz, whichever sounds best).
I know the really low frequencies rob power, but a low B on a bass is about 31 hz, an E is about 41 hz, so I suppose ill be cutting that, but ill play around with it and expirement.
Thanks again
Dew
Also, I basically dont know anything about drums, so I'm wondering; what range of hz does a kick drum run?
Can you \"google it\" and get back to us.
Love to here your answer.
If possible can you get other drum freq's and the cymbles
Thanks for your help
Mark
