Driverack PX Setup - EV Speakers
Greetings,
While working on a setup for a client today I discovered that their top boxes, EVSXA250, aren't in the DRPX's native library. I'm not terribly familiar with these EV's so I picked a box that I hoped would be fairly close, the Mackie SRM350. Now that I'm back in front of a computer I realize that I probably chose poorly, lol. Anyway, as I went through the RTA process, the PX would never get past the \"Right-Left Balancing\". It would just advise me of the incomplete status of the setup, instruct me with amp level settings and start the process over. After 3 times I decided it wasn't going to get any better and forced it to move on. I set the \"D\" curve, ran the noise, and it eventually completed the EQ and FB processes but ended up sounding rather tinny. Maybe the room is really that bad? So, does anyone have suggested settings for this EV box?
Awesome forum here... thanks for any light you can shed on this!
Setup
Stereo
2 - Mackie SWA1501 subs (stereo for now)
2 - EV SXA250
1 - DRPX
Setup
Stereo
2 - EV SXA250
1 - DRPX
So,
hipass BW 18 @ 30 hz,
lopass @ LR 24 111.7 hz
thats the subs
Hipass @ 118hz LR 24
lopass.. you don't have one so it's said to be
>out
Unless you want to EQ each side separately select stereo, or linked stereo.
Mic position is CRITICAL when Auto EQing... the WORST place in the world is between the two stacks, with multiple arrival times and reflections you have set yourself up for a really crappy sounding system, placing the mic on a mic stand only exacerbates the problem with further reflections and multiple arrivals. Have you read the \"read me first before posting\" section? We deal with many aspects of tuning systems and the Auto EQ process.
Try setting the mic up nearfield with one side only running. Mic on a stand( this is nearfield measurement and the mic stand position will have minimal effect on the process) about 5 feet from the EV's pointed between the woofer and horn... are these things stacked on top of the subs?
Why would you use the \"D\" curve? I recommend flat or \"C\" but flat will be the truest , and then taylor the sound to your liking after that.
Try that and see what happens
EV's are on extension poles above the subs. The process you're describing here is what I used to use with my old RCF / JBL driven front-loaded mono stuff back in the 80's and 90's with my trusty old RANE 27-band. 8) However this was back when I was doing it every day and I knew my system inside and out.
I tried C and D with the above-mentioned EON system and found D to be pretty pleasing to the ear. I'm not married to it though and will certainly try some other settings as you suggest. Thanks for the help... it's going to be a month or so before I get to tinker with this guy's system again but I'll be sure to post up and let you know what happens.
Reflected cancellations are most likely the reason your system sounds tinny... when a frequency reflects off something and arrives at the mic out of phase the mic doesn't hear that sound even though it is there... the Auto EQ then boosts that frequency trying to \"hear it\" and boosts it dramatically, but it cannot get that frequency back adequately...Now move the mic a few inches and the playing field changes because the reflected paths are different. Averaged multiple location Auto is the only way to see what the room is doing to the sound, so your best to go in with an equal energy system (flat response) that won't excite the room unevenly, and then if you know what you are doing, take some auto EQ measurements in divergent locations and extrapolate the information to get a solution. Unlike the FFT measurement systems that take into consideration time, phase and other factors into consideration, the Auto EQ is simply a LOUDNESS/frequency based system. and it only takes 28 points into consideration and the higher the frequency the farther they are apart.
Yes I meant do NOT NEED tunings... ONLY bi-amp, tri-amp, and so on that DON\"T use internal speaker crossovers... need tunings...
Note... if you intend to use the method where you use the floor or ceiling, you need to take into consideration ALL reflective surfaces in between the speakers and the mic, and you need to move the mic out till it is in the direct field of the horn AND the mid, the subs are less important since they are omni in nature...SO if the speakers are 7 feet high to the center of the horn and the pattern is 55 degrees vertical you probably need to be more than 10 feet out... calculate the angles, you'll start to see a pattern.
I'm and old school guy too but this new DSP technology BLOWS the old crap to the stone age! I recently converted my monitors to the 4800... OMG what a difference... I will NEVER buy another analog GEQ...\"KT\" or otherwise...Make sure you read all the stuff provided as there are pearls of wisdom throughout, even if it's not what you are doing right now...
I just didn't understand them lol
OK, isn't the purpose of auto eq'ing using the RTA mic is so that you can set the delays, set the room size, etc...
In this venue I can do that as I will be alone in the building prior to opening.
Can you post the FAQ that you want me to re-read again?
Maybe I should set-up a new thread as I have a 260 and not a PA. Sorry for the hijack.
http://www.dbxpro.com/forum/viewtopic.php?t=959
and this:
http://www.dbxpro.com/forum/viewtopic.php?t=949
and this:
http://www.dbxpro.com/forum/viewtopic.php?t=953
and this:
http://www.dbxpro.com/forum/viewtopic.php?t=1058
and you can then start a new thread with a basic knowledge of what Auto EQ is, what works and what doesn't...
Please note that alarms started going off in my head when you said the stage is 3-4 feet high... you better read this:
http://www.peavey.com/support/technotes ... lation.cfm
and find out why...
