How long does RTA mode normally last?
aardvark5
Just had the PA and linked it to Mackie SWA1501 subs and Mackie SRM450 tops.
I gigged at a pub on friday, setup the pink noise and after 1 minute the landlord told me to STFU.
How long does it normally go on for?
I'm sure someone here can give a better answer about how long it should take. I do know that it varies from one site to another. I have changed mine to 'low' when the process had timed out on 'med'. This is probably not the best solution to the problem, as I think that time-ing out must indicate an acoustical problem in the room such as a 'mode' or some problem frequency. However on the occassion that I have done this I did not notice any problem with the sound after completion of RTA process.
My position .. is that a properly tuned system in a room is far better than an uneducated person trying to use the Auto EQ to try and EQ the system with respect to the room...and a whole lot LESS painful...
Will try ASAP.
