Delaying Mid Towers
digimaxdigimax Posts: 4
edited May 2008 in PA General Discussion
I am using a driverack 260. Trying to set up an output to a mid tower. I have a momo sub out and sterio mid/hi out. I am using output 4 for the signal to my mid tower. My problem is the delay on that output only allows me 20ms delay and I need 200 ms delay to align the mid tower. In the config dialog box there are many delay options but there are only two available with 20 ms the greatest. is there a way to get a greater delay time available in output # 4. thanks ,Gary
  • GadgetGadget Posts: 4,915
    edited May 2008
    Go into the \"Confiig\" mode by pressing the \"config\" button or the config button on GUI and re allocate the delay. It's really simple on the GUI, just right click on the delay box(output 4) post xover, and select the amount of delay you want. On the front panel you'll need to use the delay button and select output 4 and toggle using the data wheel and NEXT> PREV< buttons.
  • DraDra Posts: 3,777
    More info. Be sure to go to the Pre-x-over delay module and config it to 0-msecs. The main thing is that there is a fixed total of delay available (2.72 secs), divided among the pre-delay(s) and the 6 post delays. If you max one then you limit the others.
