Home dbx User Forum dbx Archive Threads DriveRack 4800 4800 General Discussion
LCD on 4800 flarhin
mhuuskomhuusko Posts: 7
edited May 2008 in 4800 General Discussion
Why is the LCD on my 4800 flashing?
How can I stop the flashing LCD?
  • GadgetGadget Posts: 4,915
    Did it just start flashing? or did you try and upgrade or something like that? What version of software do you have? Have you backed up your presets to the computer? Are you using Hi Qnet? if so are you using the serial hookup or Ethernet? so many possibilities...
    We may need to contact tech support on Monday...
  • mhuuskomhuusko Posts: 7
    My 4800 is ethernet connected.
    Firmware 01.01.04.00.
    Driverack DLL 1.7.0.1
    All programming i done from a PC, No Hi Qnet connections.
    Only way I could find to stop the lcd flashing was power off.
    /Markku
    The only advise I can give at this point is to update to the latest software which addresses some of the problems associated with the issues that have sprung up since it's release...Remember to back up your programs before doing so. I would also disconnect the Ethernet cable and see if that helps. Could be that the external control is causing the glitch. If not export your programs and upload the latest version of firmware and see if that helps.
