Consumer-level inputs - Gain settings?
I plan to feed the outputs of a consumer level pre-amp into the 4800, going through some Jensen transformers (1:1) first to reduce hum and go from single-ended (RCA) to Balanced (XLR).
I've been feeding a DR260 this way for years quite effectively.
But with my new 4800, we now have more analog gain settings available and was wondering what the members would recommend as a good setting for this configuration.
Any other tips for this type of config would also be welcome.
I'm still curious about the multiple analog input scale setting the DR4800 has, so I'll start is +16 on input and +8 on output as I do the gain management setup.
The outputs must be routed through resistor banks, as I hear relays clicking in the 4800 when switching output levels in the config panel.
The pre is rated for Std consumer 1V outputs, with an impeadance of 100 Ohms.
With respect to gain matching, I just love the new selections.
I used 14 dBu on inputs and 12 dBu on outputs and that mates just fine with the consumer gear I have.
Here is a thread on the MartinLogan Owners forum describing my experience and setup of this unit in my high-end home theater:
http://67.19.167.226/~tdacquis/forum/sh ... 543&page=6
The link is to the page where I talk about the DR, but you might want to check-out the whole thing plus some links for details on how I use DR's to do crossovers on my MartinLogan Electrostats.
