Adding Monitors
D1LLeXD1LLeX Posts: 7
edited June 2008 in PA General Discussion
Hello,
I've been using my driverack PA with a \"one amp, one set of mains\" set up for quite a while on a 2X2 preset. I'm about to add a set of monitors and another amp. My main amp is a Crown XLS 802 and the amp for my new monitors is an XLS 402. My question is, what setting should I use for this new setup. I dont really mind not having much adjustment on the monitors because I want the play exactly what the mains do. I plan on controlling volume with my sensitivity knobs on my amp. Any help will be greatly appreciated and if there is something that i havent specifed that is needed let me know and I'll answer the best I can.
Thank You.
  • Fanman20Fanman20 Posts: 223
    Hi D1LLeX and welcome
    First question was:
    Use the same setup 2 x 2
    FOH into the Left DRPA
    Monitors into the Right DRPA
    Left high output into FOH amps
    Right high output into monitor amps
    Important fact to note is DRPA links (L + R) Compressor, Sub harmonic synth, AFS notch filters together. The GEQ however can be unlinked so that you can eq FOH and monitors separately. (the only thing you can change separately) (See block diagram on page 4 of manual)
    Be sure to unlink geq.
    See page 6 of manual.
    Simply rotate the <DATA> wheel to select either a Dual Mono or Stereo linked 28-band
    Graphic EQ. Once you have selected your EQ option, press the <NEXT PG> button and
    the display will appear as follows:
    Next question
    That's good!
    And
    Good again. The only way you can go.
    Hope that helps
    Mark
    Thought :idea:
    Does all this mean that this DRPA has been essentially turned into a
    Stereo 1/3 octave graphic :?: :?:
    Mark
    :cry:I should have brought a 260
    :( :oops:
  • DraDra Posts: 3,777
    Fan is right, but..... you can add one more layer of control.
    Set up a 2 x 6.
    Move the monitor out to Mid - Right. This add the ability to use 3 PEQ's on the mains (Highs) and 2 PEQ's on monitors (Mids). Separate Limiters for mains and monitors. Separate x-over (filter control) for each, which is good because you'll what to set a much higher HiPassFilter (lo-cut) on the monitors as well as LoPassFilter (hi-cut) if desired. Plus output level control at the DRPA.
    Yes
    Dra is more \"righter\"
    Much more better. :wink:
  • GadgetGadget Posts: 4,915
    Under the circumstances \"ain't that\" \" Morther gooder\"?
  • D1LLeXD1LLeX Posts: 7
    Fanman20 ... if I do things that way won't I loose my left & right on my mixer??? would I not be able to pan left or right & wouldn't only one slider work for the mains???
    actually what I'd like to do is set it up as if I am running 2 sets of mains all at full range...
    what setting would I use for that & would I hook into the mid or low output
    Yes it does
    Mono only out of desk
    (left output)
    I never run a stereo mix. Only mono
    Unless you are sitting some were in the middle of the room you don’t really receive the benefits of a stereo mix. I prefer to keep to mono.
    What is in your mix?
    Gtr/ Drums / Vocal???
    Why not just loop out of your main amps into your monitor amp?
    Mark
    You can set up a 2 x 3. Stereo mains by coming out the highs and setting the crossover filter to \"full range\" (with a high pass). Connect the monitors to the Left / Mono out and set the x-over filter to \"full range\" ( with high pass). You'll have separate PEQ's & limiters plus gain control, but common GEQ and FBX. Auto EQ will be mostly (more than usual) useless.
    Note: if you were to add subs, then you would set up a 2 x 5 and put subs on the mid outs.
    my set up right now is as follows soundcraft 14 channel mixer to a 50' snake to drpa to crown xls802 to two jbl jrx125 speakers
    we're a small 4 person band & play small venues we mic everything ... drums have a drum mic set ...we mic the guitar & bass amps
    the monitors are to be for the singer mainly
    what I want to add is another crown xls402 amp & 2 generic monitors
    you have given me alot of choices which, right now, have me more confused
    a few more questions: if I go mono like fanman said how will it effect the amps? when I Use the same setup 2 x 2
    do I use a single input into the amp or do I need y cables
    or how would I loop out of my main amp into my monitor amp, wouldn't I need low level outputs from my main amp to go into my monitor amp???
    the simplest way to add the other amp & monitors is what I'm after right now... I can experiment with the other ways at a later time
    also thank you all for all your help so far
    why can't I just do a 2x4 setup with all running fullrange & if I can do that what drpa outputs would I use & how would I set them all to full range??
    Re-read the thread. The answers are there.
    \"a few more questions: if I go mono like fanman said how will it effect the amps? when I Use the same setup 2 x 2
    or how would I loop out of my main amp into my monitor amp, wouldn't I need low level outputs from my main amp to go into my monitor amp??? \"
    if these questions have been answered already I can't find them
    I'm sorry I'm asking so many questions but I just don't want to mess up anything that I have working so far ... I'm new at this & just getting where I am now was quite a learning curve... in the post I see several different options... none of which I fully understand
    Clearly you have a lot to learn here....have you read the \"read me first before posting sections?\" If not it's surprising your getting any answers at all... it is a prerequisite here... one I have mandated, and with good reason. Dra, Kpippen, Fanman20 ...and a lot of other good folks that have helped out here over the years are all volunteers... we cannot do it for you...all are here to help. All are in agreement that you need the basic knowledge of what the Driverack is and what it does, and a basic knowledge of what is going on in sound reproduction. Without this knowledge you can do more damage than good with the DRPA...the learning curve is steep, but if you read and ask informed questions you will do well with it. Contained within the \"read me\" sections, are questions that have been answered a thousand times...and information that gives you what you need to start learning, and formulating questions from a position of understanding of the principals involved here...there are no shortcuts. We can tell you what to do but then you'd be lost if something happened...
    Now, what if anything do you need to run stereo? Consider the person or persons sitting stage left at a table to the left of the speaker.... what of the information that is panned to the opposite side will they hear? I run stereo, but I ONLY run stereo instruments like the keyboards, and stereo guitars, and mostly effects in stereo...
    If you answered the question NONE... then if you run the amps stereo... one cab per channel....use the parallel input feature that sends identical signals to each channel from the left/A/ channel input...Or if you want more power (and HAVE the added power available at the wall outlets) to run bridged mono....then you don't need the parallel feature...
    If the above fits use a 2x2 if you want to hear what the FOH is hearing use a 2x2 and feed the monitors from the right channel of the DRPA and the monitors from the left...if you want MORE... then READ.... the answers were given to you in detail by DRA and Fanman... and me in the FAQ section...
    The learning curve is steep... we have met it and it is our solace...We may not know everything... I doubt that anyone does, but we have put in the time and learned the basics and we pool our knowledge. Do yourself a favor... answers without reason are useless... do the work...
    Moderator...
    I do appreciate all the help & I do have alot to learn....I understand going mono with the mains & monitors as fanman suggested...that is what I'd like to do... i understand how to do the inputs but on that setup what confuses me is going from the drpa to the amp to the speakers....
    again I apologize for my ignorance...and I have read everything I could find on adding monitors in the fourm
    Hi D1LLeX
    The Crown XLS 802 amp doesn’t have \"loop though\" xlr connectors so try this setup.
    This will work for the
    setup 2 x 2
    Left high output of the DRPA into a \"Y\" cable then into the FOH Crown XLS 802.
    Into the Left input and right input.
    Out of the amp left and right into the speakers
    Do the same with the foldback Crown XLS 402
    Right high output of the DRPA into a \"Y\" cable then into the foldback Crown XLS 402
    This is 1 way of achieving your aim.
    Hope this helps
    Mark
