Set up for crossover, limiters, and compressor settings
DJ Brad
Set up for crossover, limiters, and compressor settings for DJ set up and when I also mix a small local band using two EAW tops FR153z and two EV subs QRx118S, one Mackie FR2500?
For example... you can't use a compressor AND a limiter together...and compressors for whole mix live setups are not advised...
Crossover point is tied to driver size, and power
Moderator
I have already read those facts you are referring me to, If you could kindly go over with me the Settings for crossover, limiters, and compressor settings a small local band using two EAW FR153z and two EV subs QRx118S, one Mackie FR2500?
I also need DJ crossover settings crossover settings for my PA system above.
These are the specs for my equipments:
EAW FR153z
PERFORMANCE
Frequency Response (1 W @ 1m)
±3 dB 60 Hz to 18 kHz
-10 dB 48 Hz
Axial Sensitivity (dB SPL, 1 Watt @ 1m)
Full Range 97
Impedance (Ohms)
Full Range 8
Power Handling, AES Standard (Watts)
Full Range 500
Calculated Maximum Output (dB SPL)
Full Range Peak 130.0
Full Range Long Term 124.0
Nominal Coverage Angle, -6 dB Points (degrees)
Conical 100
Recommended High-Pass Frequency
24 dB/Octave 40
EV QRX 118s
Specifications
Frequency Response (-3dB) 45 - 150 Hz
Recommended crossover frequency range 100 Hz, 24 dB/Octave
Recommended High-pass frequency 36 Hz, 12 dB/Octave minmum
Long-term power handling 600 watts
Short-term power handling 24,00 watts
Frequency Response (-10dB) 38 - 250 Hz
Sensitivity 1W/1m 98 dB
Max. SPL / 1m (calc); full space 131 dB
Low Frequency Power Handling (continuous/program/peak) 600/1200/2400 Watts
LF Transducer EVX180B
LF Nominal Impedance 8 Ohms
Color Black
Color White
Flying No
Input Connections Parallel Neutrik® NL4
Outdoor No
Chassis Size 18 inches
Speaker Type Subs
Weight Net 45 kg ( 99.21 lbs )
Dimensions (HxWxD) 902 x 450 x 599 mm
(35.51\" x 17.72\" x 23.58\")
Have you done the Gain Structure? (Detailed in the section yopu already read)
You are the only one that can set the limiters (detailed in the section that you already read)
Do you have any more questions?
How are you powering the speakers. I assume that the EAW are off one side of the Mackie and the subs are off the other???
Mackie is 750 w into 4 ohm
http://mackie.com/pdf/FRSeries_OM.pdf
Suspect you are under power in the subs if this is how you are wiring them up
The power of the amps is relevant in determine to crossover point.
Mark
But with the info provided cross the subs and FVZ @ about 120 hz. If you do a proper gain structure you will know exactly where the system clips, and if your smart you'll give the system 6-10 db of headroom below clip... there are fairly complex formula's for figuring limiter settings...but they are only as good as the limiter.. and in this case the DRPA's is not the best at that purpose.
The brevity of your post was the reason I jumped you... one of the first lines of the \"read me first\" section says that we need info... if it's not provided you won't get answers... simple as that...we should not be expected to look up the equipment and specs, and we prefer specific questions.. not open ended all encompassing questions....some people expect us to do all the work... were all volunteers here.
Should i go stereo or mono?
QSC RMX 2450 specs:
http://www.qscaudio.com/products/amps/rmx/rmx.htm
Doesn't sound like much of a choice to me...
Bridging Is different from switching from stereo to mono right?
You need to do some home work on this subject.
http://www.peavey.com/support/technotes/
This is a good place to start. There is an artical on bridge amps
QSC 2450 =
2400 W into 4 ohms (Bridge)
500w into 8 ohm (stereo mode)
Mackie FR 2500 =
2500w into 4 ohms Bridge)
575 w into 8 ohm (stereo mode)
You can go either way with the amps
Some amps deliver better low freq than others. So Try both ways
Read this artical and get back to us with more questions
Mark
These are the settings I came up with according to my speakers, and Amps specs:
EAW FR 153z/ EV Sub QRX 118s Settings
EAW FR 153z- High 40 HZ BW 18 or try LR24 Gain 0 or 1.....3 Limiters Knee 4-threshold 1
Low-crossover @ 100 Hz BW 18 or try LR24
EV QRx 118s subs - Low @ 36 Hz or try LR24 Gain 0 or 1...3 Limiters Knee 4-Threshold1
Now, can i get some mannual suggested settings for the EQ Section (28-GEQ and PEQ) in the driverack?
X-Over
L-35.5-LR24-Gain 0 Limiter Overeasy 4-Threshold 4
Crossover-L 100-LR24
H-100 BW18-Gain 0 Limiter Overeasy 4-Threshold 4
No need to use the Equalizer settings for those speakers.
Also try LR-24 for both the sub - top and top to sub filter type. Use BW-18 for the HPF (low cut) of the sub.
This is the reason we ask people to read the FAQ section BEFORE posting. There's all the info you would have needed to do this...
Crossover points and why we choose them..
what factors figure into these xover points
what the crossover types are
how to Auto Eq, and why
as well as a number of sound reinforcement principles...
and a whole host of links, like the one Mike (Fanman) gave you.
It's all there...
Every speaker mfg says that their speakers are flat response... those with frequency plots only measure a single cabinet and thats not a very big cross section, and no matter how good the quality control is there is a fair deviation in every driver that means that each speaker is a little different.
This is why I ask people to read...
