QSC GX5 SETTING IN DRIVERACK PA
2»
  • GadgetGadget Posts: 4,915
    Same setup ...swap amps... the 2450 will be fine as a sub amp @ bridged mono... it's just a bit better sounding in the upper range in stereo. I use the 2 - 2450's bridged on the mids on my Yorkies...thats 2 - 15\" 3\" voice coil woofers that run down to 90 hz. They are -3db, and the subs are +6 and the horns are +3... so they kick some ass.
