PEQ-lists?
Hi there. I´m new to this forum and really learning allot from you guys.
I have a question about the PEQ in my DRPA.
Are there SPECIFIC settings for different speakers?
(Are my ears not good enugh reference for good sound
And if so where do you get your hands on that kind of information?
I use a pair of Peavey SP3 in a biamp mode as tops
and a pair of MACH 218 equipped with Beyma 550 as subs.
The rig is powerd with LabGruppen 1000, LabGruppen 2000c and
a LabGruppen 4000.
Cheers
Roger
a LabGruppen 4000.
Cheers
Roger
Those amp numbers don't jive with anything I have so thats not useful in determining a crossover point for the subs and mids...
http://www.peavey.com/support/software/ ... resets.cfm
Here is what Peavey says...
Bi-amp (no sub)
Horn
F1 - 800hz -3db Q.5
F2 - 8800hz -3db Q.5
x-over - 300hz LR12 0db
Low
F1 - 125hz +8db lo shelf
F2 - 630hz -3db Q1
x-over - 800hz (yes 800) LR24 -3db
Delay - 0.27ms
Tri-amp (with 2 x 18 subs)
Horn
F1 - 630hz -5db Q.8
F2 - 2320hz +2.5db Q.7
F3 - 9700 -3db Q1.2
x-over - 300hz LR12 +1.5db
Mid
F1 - 400hz -2.5db Q.5
x-over -
100hz LR24
800hz (yes 800) LR24 -2db
Delay - 0.25ms
Sub
on your own.
Good luck.
Depending on the configuration, and actual amp power...(in stereo you'd be under powered...) so you'll probably end up around 120 hz The READ ME FIRST section has all the info necessary for this.
But I´m a bit confused over the last reply from DRA.
Does it really matter if two speakers share some frequensies?
I´ve heard about cancelation but is there a risk of that in this case?
Cheers
Roger
What we need is the actual amp models or the 4/8 ohm and bridged mono power @ the same impedance to determine a xover...
What happens when two drivers in the same location(close proximity) reproduce the same frequency's simply put cancellations occur which cause intelligibility of sound to become compromised...and yes ... with that much overlap, there is a great deal of certainty that will happen...
Specs for the amps are:
Lab1000:
2 x 350 W into 8 W
2 x 550 W into 4 W
2 x 675 W into 2 W
at clip level with both
channels driven
Lab 2000:
2x1000 W into 8 W
2x1400 W into 4 W
2x1400 W into 2 W
at clip level with two
channels driven
Lab4000:
2x1300 W into 8 W
2x2100 W into 4 W
2x2400 W into 2 W
channels driven
These are RMS powerratings.
Are you saying that the crossoverratings are wrong on the Peavey-website?
So are the Bridged 4 ohm ratings double the 4 ohm stereo ratings?
Lab 1000:
http://www.labgruppen.com/media/Lab1000 ... +specs.pdf
Lab 2000:
http://www.labgruppen.com/media/Lab2002 ... +specs.pdf
Lab 4000:
http://www.labgruppen.com/media/Lab4000 ... +specs.pdf
Dont be afraid of the links above, they are only two pages long and quite
easy to understand
peaveys spec-files that DRA spoke about. I dont have
the correct software to open them
Cheers
Roger
With 380 watts per channel in stereo you are limited at best... double that would be good, and thats what you get in Bridged mode...
With 1000 watts per speaker in Stereo... again you'd be lacking, and would have to compensate in xover point (raise the xover pointbetween sub and lomid) In bridged mono you could cross lower, giving a cleaner tighter sound.
Same story with the subs...(I suspect since I have no idea what happened when you put in a speaker that the cabinet wasn't designed for...)
That stated:
RUNNING THE AMPS STEREO...
____________________________
Cross the lo mid to passively crossed hi pack @ 650-800 hz LR24(lean twords 800)
Run the Lo mid (15\") 120- ____hz see above xover point...( a few hz SPREAD would be appropriate here...
Again knowing LESS THAN NOTHING about the subs
HPF the subs @ 45 hz BW18
LPF is again tied to the Lo mids...(just below) 120 hz LR24
RUNNING THE AMPS BRIDGED MONO
______________________________...
Cross the Lo mid to passively crossed hi pack @600-650 hz LR24
Run the lo mids HPF 100 hz LR24 to whatever the above is (or better just below)again LR24
LPF the sub again @ 45 hz BW18 HPF LPF @ (again just below)100hz LR24
Depending on if the subs are 4, or 8 ohms...( you can run 2 ohm stereo, but not below 4 ohms bridged...)
The latter would give the best performance BY FAR... BUT would also draw SIGNIFICANTLY more power from the wall... (edison)
I will try the settings you´ve suggested.
I will now dig further into the DRPA to make my rigg
sound it´s best.
Once again thank you.
Cheers
Roger
