RTA Freakin out!
Just install new 260. Setup xover points and ran through general operation to check it out. Everything seemed to be good. Ran a quick Auto EQ and it ran fine, resulting in a \"better than expected\" end result. Did this a couple of times as I changed xover points and amp settings just to play around. Again, all fine. Came in tonight and set new xover points and attempted to run Auto EQ - now with problems. I select the Wizard, then set \"EQ on\" and \"hi\", then hit next and run up the pink noise (have tried several times at different settings, but just below performance level), then I hit next to start the auto eq process. This is where the \"Auto\" part is suppose to happen. Instead, the RTA display registers low readouts and then the unit pushes the levels up on its own, not once but twice! Jumps from -30 on the meter to +6 in level without touching it. When I rotate the knob between RTA and EQ, the EQ levels are off the chart. All bands are pegged. Nothing I do fixes the problem. Tried a soft reset but no help. Other than this the system seems to be working fine. What am I doing wrong? Need to fix this before this Thursday!
So your saying that the auto EQ BOOSTED the level on it's own? The Auto EQ needs a sufficient level....which seems REALLY REALLY loud but geez... +6 would throw the cones out on the dance floor in my system! (I like lots of headroom)
-30 seems really low...I think mine was like -10 ~ (roughly)
Try it again with a higher level...I recommend (if you like a bass heavy mix like I do) that you decrease the level of the bass amps by 3 - 6 db and EQ them by ear. When I EQ the room the owner thinks the foundation sinks a few inches, and fully expects a call for the earthquake monitoring stations advising of a seismic event :shock: in our area...
I think mine won't let me Auto EQ without a sufficient level... but I could swear it just alerts me via a front panel message...
Maybe I should try a hard reset... Dan
Dan
Other question. before I did a soft reset when the unit powered up it automatically muted all the channels. How do I set that back as it was?
Thanks... Dan
P.S. Dra I guess I keep my cords \"up to snuff\"
As for DBX I have contacted them on numerous occasions...and have received nothing...VERY curious...
stop taking that snuff!
It's bad for your health you know
Mark
Has \"The Phantom\" got any thing to do with it??
Mic cable lost a leg / high resistance, mic not recieving 48 volts
Maybe lost eath / pin 1
Mark
Thanks again...
With regard to DBX, they should know that, if not for this forum, I would probably have sent my first unit (DRPA) back and forgotten about DR's (or gone to another brand with a better manual), much less have moved up to a 260. DBX should either make this forum EASY to get to - or get off their collective butts and get as much of this stuff into a comprehensive user's guide as they can...
There is a direct link on the main page under \"Quick Links\".
DriveRack User's Forum
Register for FREE Account
You must be looking too hard.
What was wrong with the mic cable??
What pin was missing??
Mark
