DRPA + Amp selection
koomatechkoomatech Posts: 2
edited June 2008 in PA Configuration Wizard
Hi, I'm using a Yamaha EMX5000-20 powered mixer. Does anybody know what should be the setting for the amp selection on the wizard? If it is the custom, what do I need to set if for? Please help...thanks.
  • DraDra Posts: 3,777
    Are you running a simple L/R full range set-up using the onboard amp via power amp in?
    If so, yes, \"Custom\".
    PS - Read the READ ME FIRST section. Great info there.
