Delay set up questions
Our gear is as follows:
Two JBL SRX722s (dual 12�s and horn) and two JBL MRX518s (dual 18�s) all driven by Crown amps
Stereo system…Behringer Eurodesk 24 channel mixing board, 8 channel Alto compressor/gate (to kill some ringing toms on the drums) and a Lexicon MX400 FX processor. That’s it…simple system.
Three vocal mics…. two SM58s and one Audix
No stage guitar or bass rigs….we all use floor board pedals direct to the mixer.
Two Mackie powered monitors for stage side wash.
One Xti1000 in stereo on the horns 8 ohms - 275 watts per side
One XTi4000 in stereo on the mids 4 ohms - 1200 watts per
One XTi4000 Bridge on each sub 4 ohms - 3200 watts per
...and of course the DriverackPA....
I've set the gain structure using pink, set up the limiters & input the Wizard items etc....
Now it's on to the delay....
Most of the rooms we are in are about 30 to 60 feet deep.
Can you give me a general delay set up to start with?
I believe the delay method that Gadget recommends is (I think) in the RMF section.
Yea....the tunings page won't load for the SRX700 series....
ahhhhhh....what's the "RMF" section???? "realy munchy fries"..."roasted marshmellow fudge"???
are time aligned and you here the sub and HF at the same time.
This makes your system sound tighter.
You don't have folded horn subs. The only other reason to use delay
is to delay top and bottom equally to align with back line of stage so you
hear guitar and bass amps at the same time as the pa cabs. And that
will only help if your instruments amps are less then 10 feet or so behind
your PA cabs. (if you have the DR260 then you can delay your PA
a 1/2 mile if you have a stage that big)
So I have front loaded Yamaha 215 Subs and I am using the BW18 at 35-40HZ and the L/H x over point 95-100 HZ LR24. I should delay the top
7 or 8 MS then? Thanks for your help.
The yamaha 215 drivers have been swapped for 1508-4 SPS BWX peaveys (4 Ohm) wired in series so I can have 2-215 8 ohm cabs running off a QSC bridged amp at 4 ohms 3100 watts. I'll be about 1000w under
what I would like to have but am in between the cont. and Prog rating.
Will have to save up for a bigger amp. Each 1508 is 500 c/1000 p
so I should have really have and amp that could do 4-5k bridged @ 4 Ohm
Top cabs will be 2-Peavey SP2 with 1800w bridged mono QSC PLX 1802
I have found that the peavey sub cabs (SP118) 8 ohm rated at 1000 P cannot handle hip hop sub freq's very well with 2 of them running off an RMX 2450 bridged.(1200 per cab) They blatt out a little but thats hip hop (much more sub material) than you get from a rock band.
So I hope I'll be okay with what power I have for now. It is my understanding that impedence of a sub driver is derived by lowest ohm rating in its freq range so a 30-300hz driver may be 4 ohms at 200hz
but can actually be as high as 20-30 ohms in the 60-80hz range. So in effect you are not really getting as much power as you think you are.
P.s. I got bad info I guess from training, or not enough!
The front speaker in a series run takes a lot of punishment becauese all the power run through it to get to the second speaker. If either speaker fails, you lose both of them. In 4 ohm bridge each of your 4 speakers gets 775w, but 2 off them are taking a beating. If you re-wire and run parallel at 2 ohms stereo, each speaker still gets 775w, but the power is now evenly distributed.
That makes more sense and the amp is getting the same load either way.
Note: the Pro Rider series make excellent subs!
You have already addressed the power issue and that again, I would move the xover points..As I said, I'd start @ BW 18@ 45hz.
You might consider moving the HPF/LPF of the tops/subs xover up a bit for power reasons as well...
They do not have a DR. Maybe checking that the RMX 50hz filter is on is all I can do for them. (or tell them to get a DR)
The Yamaha cabs are sw215 4 ohm that were avail in the early 90's. Good subs but only 400w P each. I needed more power and the Peavey low rider drivers need way more power than I need. I know the 1508 is not technically a sub but its in the power range I need. The yammies original drivers are 40-2k range and the 1508's are 40-500k. (yamaha used JAY60070 15 in drivers).
The numbers I stated are for my setup with the BW1508 loaded sw215 cabs and SP2 tops. So you think 45bw18 and 110 LR24 ?
sorry I threw you a curve by mentioning the sp118.
So maybe I'm still a bit confused here, do YOU have the SP-2's? or are they with the SP118's? or do both systems have the SP-2's? and is YOUR system the one that has 900 watts going to each top? (if you can find a 100 watt stereo amp in your collection bi-amping those really free's them up) you may want to move that crossover point even higher... to even as much as 120 hz. What vintage SP-2?
As for the delay in the RMF section there is a way to determine the proper delay, but again with the DRPA it might be academic... but you could just sweep the delay till things tighten up a bit.
Those are the new generation Black widows I see. I haven't had one to test yet.. what is your impression of them? I put the Lo Riders in a OAP dual 18 \" cabinet with the same dimensions as the QW boxes by peavey and man do they sound good... I have gone on record as saying that the
new SP218 subs with the lo riders may be the best bang for the buck out there in front loaded subs...
My system is these and the 215 cabs that I am loading the 1508's in tonight. 1800w briged QSC PLX1802. (900w per SP2)
and the pair of 215 (2 ohm cabs with 1508-4) PLX3102 stereo 1550w ea
What effect will too small or too large of volume of the cab have on
performance of a speaker? The 215 has 2- 4in ports.
From my approx calc I think the cab is around 4.6 cu ft internal volume.
Freq/SPL spec looks like the peak area is 50-100Hz 97.5 db depending on
the volume. range is 40-2k (same range as yamaha orig drivers)
Specs says usable range is 35-2k. Though I see the SPL in the
40-50hz range is lower with a smaller volume. and the resonant freq
goes up with a smaller voume as well. (depending on port diameter and length too)
Now, I have never kept up with the SP'2's and I have actually got a pair I \"built\" using peavey parts, but with my own specs ... cab wise, and they rock like crazy! I have however replaced the BW's with a JBL clone speaker that allows me to run fullrange and REALLY cranks with a bi-amp hi-power setup. I use them outdoors, in the winter primarily for ski hill functions that include snow board competitions where hip hop to heavy metal music is the norm...
I don't think I really get this:
... unless you mean 2 of the SP-2's and 4? of the 215 subs?
And I'm also confused about this:
since I have never seen the new drivers I can't answer the question.. what are you asking? Are you asking if you use too little power what will happen? If so, they will not perform up to that ability, but if over powered they will have the clacking sound of the sp118's as the voice coil hits the back plate, or will distort and just sound bad ... and if you let that persist they will cook the voice coils and get scratchy or cease to make sound all together, or erupt in a spectacular ball of flame and if there wasn't a grill, would puke the flaming voice coil out onto the dance floor... either way, if you listen to the speakers and DO NOT have distortion, and never see a clip light except occasionally, you are probably safe...
The speaker itself may have a higher or lower resonant frequency, but the box design sets the hpf... The thing I've been trying to impress on you is that it's the BOX DESIGN that helps control the excrusion of the woofer, and if the box and the driver don't mesh properly, the driver can over excrude, and that will let the driver mash up against the mechanical stops... In a properly designed cabinet, a properly designed driver/box will have the effect of damping the cones excrusion @ the designed power and LF cutoff. So. when set up and designed properly, with the max power the driver can handle( usually 2-4 times the peak power handling of the individual driver.. that is to say if the driver is rated @ 400watts RMS 800 watts \"program\" that an amp capable of 1600 watts- 3200 watts (and this is an instantaneous ..peak.. power NOT continuous power )peak, is not unreasonable...NOTE that if you read the recent amp power redux we just did you will see that its the AVERAGE power you apply that will KILL a voice coil, that is to say that if the amp is approaching twice it's output capability, average, it WILL heat the voice coils to dangerous... even fatal levels.
Have you seen the links I provided in the RMBPosting section? In them is the PRO sound web \"study hall\" where al things pro audio are discussed...
is there something different here?
I was doing an outdoor gig on a cold winters night and after the event I was sitting on one of my Bose 502 sub's, (only one use for them, they make good steps as well, and nesting boxes for birds..........) when I felt the heat coming out of it.
With the 502's you can place your hand inside and touch the speakers magnet.
To my suprise I could not touch it as it was \"red hot\"
well too hot to touch.
So I supose speakers can be heaters as well. If you can stand the noise.
:shock:
Fanman20 (Mark)
Peavey spec that came with the 1508-4 says
small vented box 3 cu Ft with 4\" x 6 7/8\" port Vb box tuning freq 45hz
Since I am using 2 drivers and the 215 box is 4.6 cu ft and has
2- 4\"x 6 7/8\" ports I am guessing my volume is less than it could be and
will limit excursion. Internal approx dimentions 31.5\"h x 17.5w x 15\"D
I see on the spec sheet that a sealed box gives a freq of 87hz for the 1508 and presume that is because a sealed box would limit excursion
even more and in effect raise the resonant freq?
If these cabs don't sound okay I will just have to get into buidling a better
cab.
THanks..............Steve
