Biamp setup Q's with speakon
albuht813
So I've been searching around for 2hours but could not find threads to my application... Learned a heck of a lot, but here goes.
Speaker: (2) JBL SRX 728S
Amp: (2) QSC RMX 4050HD
The above are my mid/high speakers and amps I'm currently using. I have a sub as well, but this question just concerns the biamp setup. From my research, I now know that I need a 4 conductor speakon cable to plug into the back of the speaker. However, the QSC amplifier's only will allow a 4 conductor speakon output from one channel. THe other channel is a +1/-1 output.
So with 4 XLR outputs from the driverack PA, and 2 outputs of 4 conductor speakon...how do I get a stereo biamp setup? If I am not able to get a stereo biamp configuration, what options do I have to still get a biamp setup?
Thanks in advance!!
Thanks in advance!!
From the quick setup guide, it seems to be telling me this??
L mid -> mid amp -> which speaker?? (I only have one 4 conductor speakon output
R mid ->
L high -> high amp -> 4 conn. speakon (same issue)
R high ->
OR........should it be this way?
Lmid -> amp #1 -> speakon out to L speaker
Lhigh ->
R mid -> amp #2 -> speakon out to R
R high ->
Please help me sort this out. THanks.
Isn't the JBL SRX 728S a sub???
http://www.jblpro.com/srx700/728S.htm
What are the top boxes??
Mark
The 4 conductors are
2 conductors from the left amp (Ch 1) +1 and -1
and
2 conductors from the right amp (Ch 2) +2 and -2
An assumtion I will make is that the top boxes are bi -amp boxes and that they have a \"bi -amp speakon connector\" on them
If this is true than your second option will work
Driverack out L mid -> amp #1 Left -> speakon out to L speaker \"mids\" LF (+1 and -1)
Driverack out L high -> amp #1 Right -> speakon out to L speaker\" Highs\" HF (+2 and -2)
Driverack out R mid -> amp #2 Left -> speakon out to R speaker \"mids\" LF (+1 and -1)
Driverack out R high -> amp #2 Right -> speakon out to R speaker\" Highs\" HF (+2 and -2)
(post corrected to aviod confusion)
The speaker cable out of amp must be 4 wire (speakon conectors) going to speakers
Read page 6 of your amp manual http://media.qscaudio.com/pdfs/manuals/ ... N_revF.pdf
Use CH 1 speakon (which has Ch 1 and Ch 2 conected to it)
(More info on top boxes is needed)
Mark
PS read this link
http://www.jblpro.com/srx700/BiAmp.htm
and http://www.jblpro.com/srx700/PDF/SRX700%20UserGuide.pdf
page 8
Here:
It clearly shows on page 6 of the 4050 manual, that Speakon jack 1 is a 4 pole jack... AND if you send the LF info to input #1 that it then sends the 1+/- info out to the SRX on those pins and that in fact....the SRX 700 will then have LF info @ the speaker...(page 8 SRX manual)
further if you send the HF info to the #2 input (4050), it will rout the HF info to pins 2+/- of speakon connector #1.
With a Speakon 4 cable the SRX will then get the HF info from pins 2+/- and \"ta da...\" one side all ready for inputs from the driverack.
I guess I just had to do that for my own edification....
Mark
slight error (Should read)
That better???
(The old cut and past failure)
Thank you all so much!!! I understand and I will be looking into some 4 conductor speakon to hook this thing up!!
And yes, the 728 is a typo...it's supposed to be the 725.
Thanks again!
