Filters and X-over guidance
Am using Mackie 1530's up top and a pair of peavey subs on bottom. Have tried running subs on aux but want to come back to DRPA and run everything there. I think Gadget gave me suggested filters and x-over a long time ago but I cannot locate. Subs are 18's powered by Crown XTI 2000. Having lots of problem getting solid bottom end, especially kick drum. Lacking any real punch.
Any suggestions would be appreciated.
Bridged mono on XTI 2000 that gives 1000 watts per PV118
Hipass @ 45 hz bw 18
lopass 100 hz LR24
As for the Mackie's...
LR24 @ 100 hz hipass (this is easy to move up or down but since you are only~(read that so~so) on power...Thats where I'd start)
In the READ ME FIRST before posting section,(welcome) do the gain structure, this will determine the level the subs need to be (by ear) with respect to the Mackies.. Then (if you have the measurement mic) do the outdoor method, or the new indoor method (TOPS ONLY)... and since they are tall and lanky I'd use the \"on axis 4-5 feet out midway on the speaker with as high a level as the DRPA will allow...flat response.
Store the preset as flat, use that as a basis for any room eq...
Read the info provided!
Band is classic rock, 6-piece. (keys, bass, guitar, drums, aux perc, vox)
Understand gain steps and will repeat. Setting gain on the 1530's a little more challenging since active cabinet but am usually fine with that. I think I'm going to discover that I need more/better subs but am going to go thru exercise anyhow.
Yes, had to change username, lost credentials from before. Thanks for your help.
If your handy, or know of someone who is handy with a saw, I have the perfect subs for you... the drivers are about $150 and the wood for a couple, and all the extras.. handles, paint corners and connectors a pair would be around $100 and they kick ass like crazy! I used 4 this weekend and with a pair of SP4 tops bi-amped rocked like CRAZY! I used a Crown CTS 3000 in stereo on the subs (4 ohms) and the kick and bass were so huge I barely had them on! I only saw 3 3 bars on the SPL display and they were thumpin! Best of all they are not very heavy.. Bass you can pick up an carry at the end of the night!
Any chance you got some plans for those homeade cabs?
John
:idea:
The company is Loudspeakers Plus... tell Jay I sent you (Gary Perrett Tzone productions) Phone 847.963.0725
The Driver is the P Audio Challenger C15-600EL
The enclosuer is here:
http://www.fane-acoustics.com/pdfs/Cabi ... ch125L.pdf
Fane is out of business... there is still some new old stock available BUT once the product on hand is gone... well you get the picture right? Besides the Fane drivers are WAYYY more expensive and the Paudio's have field replaceable baskets should you screw up...
My friend runs with 2 of them I add a pair of mine for some serious low end.. 6-8 would be ... well KILLER!
Now when your really serious about low end.. come see me about some LABsubs...with 6 you get poopy pants :shock:
Good luck and good building... they are really quite easy to build.. I used polly propoline (sp?)glue (be sure to moisten the pieces as per iinstructions... and it's NASTY to get off your hands... rubber gloves would be a good idea) and sheetrock screws... used some wood filler putty, and used a texture roller and some thick hi-gloss latex paint... the corners, and handles I get from :
http://www.partsexpress.com/
http://www.partsexpress.com/webpage.cfm ... N=40675317
you can get the Speakon connectors from Jay (LSP) cheaper
http://www.partsexpress.com/pe/showdetl ... er=262-832
http://www.partsexpress.com/pe/showdetl ... er=262-834
http://www.partsexpress.com/pe/showdetl ... er=260-352
the Tube is 4\" schedule 20? the thinwall drain pipe, and I used small blocks at the back of the ports and brad nails in the front where the tube meets the front baffel
They also list an 18\" version that is BIGGER heavier, and has no more output or efficiency, and doesn't go any lower frequency wise...and the driver is more ($10) but is also an option...
I haven't actually weighed mine, but using 16 ply birch, I think they are only 40-50 lbs! Your Peavey's are 73 lbs
